Cant set up a second computer with xp on it using a wired connection to dg834g
  • rfcnumba1 Oct 11, 2008
    don't have any software for router shoodn't need any coz other computer didn't need any. xp says network cable is unplugged
    Problem Solver:
  • 33 Answers
That weird connection is your Netgear router. uninstall router, set 2nd computer, reinstall router software.
anonymoose
Posted on Oct 11, 2008
Cannot connect wireless works fine wired
change the settings of your router if your laptop is using wpa change the security setting wireless connection of your router to wpa... their are many categories of security settings ex. wpa, wpa2, radius, wep, etch.... first configure thE WPA OF YOUR LOPTOP.. HERE IS THE LINK THAT WILL HELP YOU TO CONFIGURE THE WPAhttp://compnetworking.about.com/cs/winxpnetworking/ht/wpainwindowsxp.htm SECOND IS TO SETUP YOUR ROUTER CHOOSE WPA, OR WPA2
May 01, 2011 | NetGear DG834G Router
I have adg834g router supplied by BT. I have since changed my ISP to Post Office who supplied me with another router. My phone lines run right through the house but the wireless signal is poor at one end...
I understand that you would like to extend the wireless coverage in your home with the DG834G. I would suggest you to configure DG834G as an access point to extend the coverage of your post office router using the below steps:
1. Connect a computer directly to DG834G on any of the four LAN ports.
2. Access the router's GUI by typing http://192.168.0.1 or http://www.routerlogin.com.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.0.1 to a free IP address in the range of the Post office router.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the Post office router to the Lan port of the DG834G
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to DG834G or wirelessly as per your requirement.
I hope this information allows you to resolve this issue.
Regards
Anand
Mar 12, 2011 | NetGear DG834G Router
How to connect laptop to netgear wireless-g
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
May 18, 2010 | NetGear DG834G Router
Cant connect to internet using the ethernet cable on virgin broadband
OK find a computer thats already connected to it, and match everything to it except the ip address, if you don't have another computer connected to it go to the routers settings and pull up all the info about wep, dsn servers, write it all down then write everything in the security settings of local network then you should get internet.
Feb 09, 2010 | NetGear DG834G Router
I dont know how to connect a netgear DG834G
No software needed for Mac or PC. You do need an ASDL account name and password.
Your ISP should provide you with this info.
Connect with an ethernet cable any port on the unit to your computer network socket.
fire up a web browser and use the url:
http://192.168.0.1
This gives you the login screen.
use
admin
as the login name and
password
as the password. If unit is second hand then reset to factory defaults by using a paper clip in the reset point on the rear of the unit (between the 4 ethernet ports and the asdl port)
You are then able to set up the router.
exact usermanual depends on which model version you have. (see label on base)
see this page and choose your exact model for full manual.
http://kb.netgear.com/app/products/family/a_id/1288
Jun 12, 2009 | NetGear DG834G Router
My main computer has internet but my other computers in the house cant find my netgear but windows cant connect
It sounds like you are using Windows Zero Conguration, go into advanced properties and de-select "Allow Windows to configure my wireless connection". Then you need tpo find your wireless utility that comes as part ofd the installtion for your wireless adapter and use that instead. On your laptop it is probably going to be Intel Pro-Set Wireless Configuration Utility.
Try that.
Gadget
May 18, 2009 | NetGear DG834G Router
LAN ports not working
make sure that the local area connection in the computer is enabled and that the drivers of the ethernet adapter are working properly.
try to reset the router by pressing the reset button for 30 seconds then if the problem still persist then that means the router should be replaced already.
Aug 09, 2008 | NetGear DG834G Router
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
