Sound Tech PL1402, shuts off after couple minutes use
On my 2007 C6 Corvette I shut it off and I can still hear a little motor sound turns on and off about every two minutes
Are the keys nearby? Corvettes computer continues to run if keyfob is within 20 feet. This leads to dead battery syndrome. The computer is designed to run for a couple minutes until your key fob is out of sitance then the car shuts down.
Nov 06, 2016 | Cars & Trucks
Got "Critical Alert Code 201" on Lennox air conditioning unit. Tech told me to shut off power to it then turn it back on, but that didn't seem to work. Any other suggestions?
Unplug the electrical. Wait 5 minutes and plug back in. See if that works. Have to wait a couple of minutes for system to reset.
Jul 02, 2016 | Heating & Cooling
Sanyo flat screen lcd 46 inch
Probably the power supply is failing intermittently, just shutting down without affecting picture or sound.
Mar 10, 2014 | Televison & Video
Haeir btu 14500 unit, shuts downs on its own after 1 minute
It should still be under warranty. I would first called the store you purchased it from to come check it out If it is not under warranty you should have a tech out to check Relay switch and the Capacitor.
May 08, 2013 | Heating & Cooling
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
No picture but have sound
Have a tech check for bad solder connections on connector GP on the main board and on the CRT G board connector SP. also to check solder on IC451.
Jan 17, 2008 | Mitsubishi VS-60719 60" Rear Projection...
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
No Picture, no sound, spinning up noise
vertical ,horizontal or power suppy
Dec 02, 2007 | Sony KV-32FS13 TV
Mitsubishi Projection TV. Works for a couple of hours and then the picture shuts off
Very often older Mits CRT's develope a slow leak of coolant
onto one of the circuit boards....various problems arise,depends
on where the drip lands....even a good tech can miss the drip
evidence.....I have pulled the chassis to the shop only to find
"wet" area under well-lit conditions.................T.
Nov 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
126 people viewed this question
 Grubhead
Grubhead
