Question about Dayton E51 Oil Filled Utility Heater
Dayton 3EV51 torpedo heater
Powers up. Ignitor sparks. Fan tries to turn but won't. When power is off the fan spins freely by hand. Don't have manual.
  • 232 Answers
Dayton heaters at one time were manufactured by DESA or a predecessor and labeled DAYTON for Grainger. I have been unable to find any specific reference material to "Dayton 3EV51".
There were 2 types of motors used. I suspect your heater has a starter relay. The solid state relay was used to allow the energizing of the start winding which would allow the motor to achieve approx 80% of rated speed, then the relay would de-energize the start winding to prevent overheating. The relay is not attached to the motor, except for the wiring.
Dayton 3EV51 torpedo heater - 5ef4624.jpgThis is what the starter relay looks like. If yours has one check to see if it is energizing the starter windings at start-up. If not it is probably defective. The part is still available at www.reddyparts.com, I think, but today's replacement part looks slightly different.
If your motor does not have the relay, then the motor has an internal start-up system which is not serviceable, but the motor is probably still available. Most of the time the motor's part number is printed on the label.
Posted on Oct 12, 2008
Fan runs but no fire on igniter plug
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 10, 2011 | Dayton E51 Oil Filled Utility Heater
Tip
Miele WT945 Dryer Problems - Stage 1 fix
STAGE 1: TEMPORARY FIX TO UNSEIZE THE FAN (5 minutes)
The immediate ‘fix’ is to reset the thermal cutout (the button in the centre of the round sensor fitted on the right hand side of the long rectangular heater box atop the drum). This restores heater power, which the cutout will have tripped out due to the absence of airflow through the heater overheating it. Then, spin the fan motor (at the top rear right hand corner) back and forth by hand to free it (it will be stiff and graunchy at first but quickly frees up. Needless to say, please remember to disconnect power before attempting this tasks otherwise you are in danger of losing fingers. Once you’ve done these two tasks, put the power back on, KEEP AWAY FROM THE MOTOR and try a drying cycle. You should see the motor spin happily and the drying commence. Also beware of the heater box which will quickly get too hot to touch (don’t worry, this is normal). While this fix is easy and effective, and may well keep you in business for months at a time, unfortunately it’s not tackling the root cause, which is a steady fluff/goo buildup in the fan box itself, which impedes both airflow and the rotation of the fan. Oiling the shaft of the fan probably won’t help – the problem lies deeper in the fan box itself.
(Note that the seizure problem is nothing to do with the fan motor itself – this is perfectly OK and will spin freely if you dismount it from the unit. It’s the dryer fan that the motor is driving (through the belt) that is stiff, not the motor. So don’t waste time fiddling with your motor (unless it’s obviously bust, but this is unlikely) despite it being temptingly accessible.)
Read my next tip 'Stage 2 fix' if you are still having problems.
on Feb 21, 2010 | Miele WT945 Front Load Washer / Dryer
Heater will not start. When plugged in, it just produces a buzzing sound. Kerosene is full, and fuses are good. What can I do?
Check for power to fan motor.....if there is power and motor does not go then the motor is bad...
heatman101
Feb 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Hello i have a international harvester model 100 diesel portable torpedo haeter. my problem is that when i plug it in i get a humming noise and it doesnt start. can u please help????
Sounds like the fan/fuel pump motor is not turning so try this. Take the top section of the heater tube off, this exposes all of the internal working parts. Now locate the fan motor and fan, try turning the fan by hand, should spin nice and easy if not take a light oil or I like PB Buster and oil bearings on the shaft behind the fan, then first set in the front of the motor, then the bearings at the rear of the motor. You do this and spin the fan by hand as many times as it takes for that fan to spin freely. Then plug it in and try to fire it off, if it worked shut it off put it back together and happy heating. If not you may need a new fan motor or could be something in your fuel pump, usually it will be motor related .
Dec 20, 2010 | Heating & Cooling
Have a 120000 btu fuel fired torpedo heater that fan spins and fuel drips but no spark
fuel is atomized by the blower fan, and a sparkplug provides the ignition source. this sparkplug provides constant ignition spark for the process.
Jan 03, 2010 | Dayton Heating & Cooling
Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Dec 13, 2009 | Dayton Heating & Cooling
Dayton E51 Oil Filled Utility Heater Logo
806 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
