Question about Logitech Z-2300 Computer Speakers
A whispering in my right speaker
When I am playing music and using my volume control there is a whispering in the rightspeaker.
Help me please.
Thanks.
  • Anonymous Dec 12, 2008
    same problem try changing the FUSE as i borrowed my mates speakers to see if myn were broken (he had Z2300 aswell) and the problem still occured..
    Scholar:
  • 123 Answers
If a fuse is blown the units will not work at all. This is the unit itself. If you have everything connected properly, the the amplifier package inside the speaker/sub is damaged. Return or replace. Nothing that you can really fix unless you are electronics savvy.
Posted on Apr 29, 2009
How can someone play music on my speakers and control volume
Scan your computer with an anti-virus. It could an anti-virus infection. After scanning it, restart your computer and then check if you have the problem again.
David
Apr 20, 2013 | E-Machines Computers & Internet
I want to know how i can make my cpu start playing music i messed up with the settings and i changed something so now even if i play a song no sound can be heard. please help me out.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 14, 2012 | HP Computers & Internet
With my speakers all i have to do useually is plug them in and away i go, but now for some reasonm there not working and not showing up in my controll panell as even beein plugged in, but they will work...
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program and test for a virus then
yellow? means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 10, 2010 | Labtec Pulse 375 Computer Speakers
The right side of the speaker is low, you can hear it but it's like there is no bass to it like the left side, sounds like the right side is like whispering to you but the left side is talking normally,...
If your subwoofer is placed to the left side try moving it to the right side or try to move it in the center. Otherwise if you are using a PC go to the control panel and click the sounds and audio devices icon. a little window will pop up and the button labeled speaker volum click on and reduce the volume for the left speaker and then turn up the volume on your speakers and see if that helps.
Nov 30, 2010 | Logitech Z-2300 Computer Speakers
My apple iPod nano 5th gen wont play music through the headphones right. It only plays through the internal speaker even with the headphones in. I can hear it through the headphones a little but it is...
take the headphones out play the music full volume then put the headphones in and lower the music all the way down then your volume will be normal and it will only play in through the head phones unless you take headphones out then it will play through speakers
Aug 30, 2010 | Apple Logitech Inc MM50 Portable Speakers...
I've plugged in my speakers and the woofer but only the left speaker will play sound and its almost a whisper
Try to check for sound manager to check balance is on for both sides (left right) and wave balance is normal value. To call master volume just duble click system tray volume icon (next to clock) and check it.
Aug 03, 2009 | Logitech Z-340 Computer Speakers
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
My lap top has stopped playing audio
Right click the volume control - select open - this will open a larger volume control showing the volumes for each type of sound. Make sure none of the sliders are muted or low.
Apr 20, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Everything connected right can't hear music.
You tube might use a different method to control volume. Check your media player's volume setting. If that doesn't solve the issue, right-click on the speaker icon in the system tray to bring up the volume control, then see if any of the volume is at the minimum level.
Also, if you can give more detail about the type of computer, make, model, etc. I can help you further.
Dec 16, 2008 | Dell A215 Computer Speakers
My Toshiba Satellite has a sounds problem
Make sure your volume controls are not muted and levels are midway.
Right Click on Speaker icon in lower right system tray and choose Open Volume Controls.
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
Logitech Z-2300 Computer Speakers Logo
118 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
