Question about Vizio L37 Television
PIP Set up PIP on VIZIO VX37L
  • Anonymous Oct 11, 2008
    i can only get a blue screen on one side of pip
  • lsdgolf Dec 17, 2008
    As I don't have a cable box, but do have an older dvd/vcr with a tuner, can that be used as the second source? It seems to only send a signal if a DVD is in the player, and not the tuner which runs thru the vcr portion. I have a composite cable coming out of the dvd/vcr, and have also tried the AV cable - which the PIP shows as not a viable second source. Why would only the DVD player give a signal that the TV recognizes as a composite source for the PIP? Is there some other way of getting the signal thru the DVD/VCR box?
    Thanks.
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and +
buttons located near the bottom of the remote. You can swap picture in
the Main and Sub screens using the swap button and swap which screen
will sound off its audio by using the AUDIO button. You might notice an
X next to some of the selections in the INPUT and PIP INPUT screens
when you have PIP activated. That means that input selection is
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
bring up that input menu you will see X's next to the TV and AV
selections. The X's mean that when you have TV on the main screen you
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Posted on Dec 11, 2008
Press "INPUT" button on the remote control while simultaneously pressing the "POWER ON/OFF" button on the television. This defeats the timer.
This is at best a temporary solution so the best move after this is to check with your warranty carrier.
Best wishes.
J & S P
Posted on Jan 03, 2009
10/11/2008@18:38 EDT
Sir:
Thank you for your quick response.Found out I had a two(2) year warranty.Purchased through American Express,extends warranty for another year.Contacted Mfg. Service call to be preformed this coming week.NO CHARGE! Again thanks.return682
Posted on Oct 12, 2008
Tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Jul 19, 2010 | Vizio VX37L Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
Vizio,model vx37L, won't turn on
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look to see if it has any voltage at the output connectors.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX37L+
Please post back what you find
Dec 16, 2009 | Vizio VX37L Television
Sudden no signal on digital channels on a Vizio VX37L
That may not be correct. You would not lose all your digital channels. Vizio has an un-addressed problem with losing digital stations. Multiple threads are posted due to this problem, which is why I am on this site. I have lost all digital stations on CATV connection. The Toshiba set in the next room is getting over 150 DTV channels, the Vizio, only analog. Zero Digital.
May 23, 2009 | Vizio VX37L Television
Lost stand for VX37L HDTV.
I'm posting a stand for a VX37L on ebay today!
Dec 05, 2008 | Vizio L32 32 in. LCD HDTV
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Vizio L37 37 in. HDTV LCD TV
I had a similar problem with my Vizio Model VX37L HDTV and replaced the main board myself for $160.00 which I purchased new on Ebay at ShopJimmy.com. The symptoms all of sudden started by the screen going blank except for a rectangular banner across the top that resembled a UPC code only garbled. No sound. I actually had to pull the power cord to turn off the TV. I was able to turn on the set normally but the TV menus did not come up. Since the TV was 19 months old and no extended warranty I checked with Vizio support and Sam's Club but no extended warranty=no luck. I did have an estimate for repair for $900 from a company Vizio recommended but a new one goes for less now. About 42 screws and a half a dozen pin connectors I replaced the main board. The set is working again better than ever. I don't know if I call my self fortunate or not since I did have a problem after only 19 months.
Jul 11, 2008 | Vizio L37 Television
Vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Jan 12, 2008 | Vizio L37 Television
VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Nov 22, 2007 | Televison & Video
Vizio L37 Television Logo
1,443 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
