1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
Purchased used turntable, only has 3 of 4 feet. Where can I purchase replacement part? Its not an...
(More)
Purchased used turntable, only has 3 of 4 feet. Where can I purchase replacement part? Its not an item listed in product manual.
After not using my turntable for two weeks or so, I turned it on and noticed that the strobe light...
(More)
After not using my turntable for two weeks or so, I turned it on and noticed that the strobe light is very dim and the platter will not spin nor will it switch from 33rpm to 45rpm. I tried everything...this unit is only two years old. Any thoughts?
