Question about Samsung YP-K3 MP3 Player
Connects to the computer but wont turn on
My samsung will connect to the computer when the usb is plugged in and charges,
but then when i take it out it wont turn on or anything.
i have pressed the reset button but nothing happens.
when it connects tot he computer the mp3 says "usb connected, charging" and my computer comes up with found new hardware wizard.
i tried completing the wizard and nothing happens
i need your help!!
  • 1 more comment
  • Anonymous Oct 13, 2008
    same exact problem
  • Anonymous Oct 14, 2008
    i have the same problem (without the new software part). Is something not connecting inside the mp3 player? It just won't turn on!
  • Anonymous Oct 17, 2008
    Yep mine does the same! :-(
I have the same problem to!! what a heap of ****!
Posted on Oct 16, 2008
My tab wont turn on
Basically, if you have to try and establish "IF" the charging system is at fault or yor Tab 2 device by substitution method.
By substitution method I mean try your charging accessory(s) on a friends working Tab 2 or product that uses same cable connection and or theirs on yours.
I can't quite fathom two of them can have same problem i.e.Tab 2 devices BUT can understand if you ONLY tried 2 different cables and NOT the USB power supply that regulates the electricity, meaning I doubt you're refering to TWO Tab 2's being faulty, but rather charging system made up of plug pack with USB connector and USB cable to Samsung Port connector.
Good luck.
Jan 18, 2015 | Samsung Galaxy Tab 2 7.0
Tablet wont charge
The charger socket has probably broken its solder connections, happens because of repeated movements straining it by using it when the charger is plugged in. Have you tried charging it through the mini usb socket?
Jun 05, 2013 | Samsung Tablets & eReaders
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
Panasonic HM-TA1 won't power on with battery fully charged.
The battery will not charge when the device is turned on. Make sure that when you connect it to your computer via its usb that you do not turn it on otherwise it wont charge.
The annoying thing about this device is that when you connect it to your computer and turn it on, on the LCD it will say "connecting via usb" and the memory bar will show that it is fully charged, however the battery is not. This must just be a design flaw as the battery won't be charged.
Just remember to plug it in and leave it, do not turn it on!
Jan 24, 2011 | Panasonic HMTA1 Camcorder
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
I bought a new usb for my yp-t10 but its not charging it anymore
it probably has something to do w/ the mp3 player not the new charger. just call samsung and see if they can possibly do something about it.
Jan 10, 2009 | Samsung YP-T10 Digital Media Player
My yp-u3 wont connect
no reconoce el dispositivo
Nov 06, 2008 | Samsung YP-U3 MP3 Player
My samsung K3 wont turn on.
Maybe you have a USB 1.1 on your computer. YP K3 will charge much faster on USB 2
Nov 02, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-K3 MP3 Player Logo
180 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
