When I start my Makita gas cutoff saw it runs fine but after a while there is way too much gas in the intake and it floods and dies .Have cleaned the carb any ideas .
The fuel inlet needle in the carb is leaking, replace the needle with a new one, the needle is rubber tipped and will wear espesially on a power cutter due to dust in the fuel tank, when replacing the diaphram make sure the gasket goes to the carb first followed by the diaphram and cover, the gasket is used as a spacer, so if the diaphram goes on first it will be too close to the metering lever and will leak.
SOURCE: my partner k950 cutoff saw isnt getting gas to the
check from the tank. is it clean? use air to blow back to the tank. most times it is trash and varnish in the carb.
SOURCE: on the dpc7311 cutoff saw what do i set the 3
one screw should be your idle adjustment one srcew will be the low jet start with a turn and a quarter with saw running at idle turn srew in both directions until it dies down then set the screw in the middle for the high jet start with the same setting but the final adjusment must be made with engine at full throttle adjust until max rpm is abtained and the back it off just a little bit too make sure you are not above max rpm
