Question about Maytag 24 in. DWU7402 Built-in Dishwasher
Water deposits on glassware
Model DWU7400AAE Maytag built in dishwasher. Tower of water sprayers, heating element, and bottom drain all coated with water deposits. Have tried rinse-aids and dishwasher cleaner.
  • Anonymous Mar 16, 2014
    Just bought our new dishwasher and we have not been able to get good results. Our new silverware has some sort of discoloration, also some have rust spots. Glasses often come out with specs. Very disappointed- our water is conditioned, 133 degrees at the sink, and we use the recommended Cascade Platinum Pacs and Cascade Complete rinse-aid. Tried changing rinse aid dispenser to 2. We started with the auto wash feature, when that didn't work, we used extra heat, when that didn't work we bumped it up to jet clean plus with high temp, with heated dry, extra dry & sanitize. With all that we still have spotting. What should we try?
  • Anonymous Mar 30, 2014
    we have check everything, we add very small amount of soap, and we still find dried soap in bottom of dishwasher. all line are good & its draining well! sprayer is working too.
    President:
  • 1,462 Answers
Arer you putting salt in the salt container?? in a hard water area, this is essential
Posted on Oct 11, 2008
Dishwasher not draining
In the bottom of your dishwasher is a grill where food particals can land and sometimes things like noodles and large meat chunks don't get ground up small enough. Get out your instructionbook for the dishwasher and see if they have a section on what to do if it doesn't drain. Best to first check your instructions or if you don't have any google the make and model and see if you can find any from the Manufacture.The bottom water sprayer piece might be able to be easily lifted off and under that you should see where the drain is. Sometimes the heating element is in the way, Make sure you didn't just run the washer because this might still be hot to the touch!. If you can get a flashlight take a look at where the drain is in the bottom and try probing with a Q-Tip. Don't loose the Q-Tip. See if you can feel around to get the layout, (if it's an elbo it will stop the Q-tip rather short in). The other thing depends on your model, some models have the grinder built in to the drain and it works on a pumping action, that as the grinder grinds it also pushes fluid like a pump.
Jul 13, 2012 | Maytag Dishwashers
My dishes come out of the dishwasher with a white milky coating on them. Especially glassware is very milky.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 20, 2011 | Amana 24 in. ADB2500AW Built-in Dishwasher
Model MDB 7600AWQ It is not cleaning dishes well and the bottom water 'slinger' is not rotating. We disassemble the lower assembly and cleaned extensive soap scum and hard water deposits. Lower slinger is...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Not cleaning properly and water has not drained out. yesterday there was a little water left in bottom and today there is a lot of water in the bottom of the dishwasher
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
j
Jun 30, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag dishhwasher turns on but no water is going in to wash dishes and the heating element is on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 01, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher comes on, fills with water, water heats, no movement of the arms so no water spraying out, then the water drains, it goes through the dry cycle and no clean dishes.
What is the manufacturer and model number of your dishwasher?
Depending on the model and design, the sprayer motor/pump has probably failed and the drain motor/pump is still working.
Recommend you pull the sprayer arm and filter. Look for debris that could be jamming the pump - watch out for broken glass when looking.
Make sure the impeller can spin and is not damaged.
If that does not fix the problem, replace the wash motor / pump or replace the entire dishwasher with an Energy Star qualified name brand model.
Good Luck!
Apr 01, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Water not hot nor warm
When you run the hot water at the kitchen sink until it is hot and start a cycle on your dishwasher, is water hot when you open the door after it stops filling?
If no, the diswasher is connected to the cold water line, not the hot water line. The water temerature entering should be a minimum of 120 degrees but no hotter than 140 degrees.
If the water going in is hot, but it cools down after each filling then the heating element has failed and needs to be replaced. When the heating element fails, the dishes, especially the glassware will be foggy and still dirty.
Please reply with what you find. Good Luck!
Mar 30, 2009 | Dishwashers
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
211 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
