Hey there. need a lil advise
I have a sony flat screen tube tv.. it was manufatured in sept. 2002 so its kinda old, well when u 1st turn it on its the clearest screen you could ask for then less than 5 mins and the screen fades out slowly to red...the sound works fine..what Is the problem and how much will this run to fix... thanks
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check out . your tv focus is bad change it with new one
Posted on Oct 11, 2008
I need a picture tube for my 50in.Sony t.v . I live in central MI. Need to know where & how , to buy & fix the pic.tube Thank You...
projection screens dont use tubes,a 50 inch tv tube will cost 1000 a new flat screen tv is alot cheaper,buy a flat screen hd ready tv
Apr 16, 2015 | Televison & Video
My sony wega screen went pink & blue then black now the stand by light keeps 5 times and tv will not turn on
This is usually indicative of a power supply or power board failure inside the unit. Unfortunately there is no easy fix and you will need repairs. Please contact Sony to see how you can go about getting a repair scheduled, or check with a local TV repair shop in your area. Sony's number for this department is: 239-768-7547
Sep 13, 2010 | Sony KV-36FV16 36" TV
TV has colour lightning like effect then turns black and shut's off. Sony KP-51HW40 51 in
sounds like you have a bad tube you can attepmt a temporary fix for this problem but is kinda hazardous and does'nt always do any good . but you can remove the front of the tv where the speakers areand tap on the base of the tubes lightly to see if you can get some of the carbon build up loose from inside the tube. also try adjusting the screen voltage for what ever color you see the lines for sometimes turning down the screen voltage can help
Jan 25, 2010 | Sony KP-51HW40 51" Rear Projection...
Hey my Nam francisco I'm in the Caribbean.
Don't know what you paid for the set but Sony's price for the panel is $620.50, may just need to get new set.
Sep 04, 2009 | Televison & Video
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
TV screen bouncing up and down
look for the horizontal hold.
Jan 26, 2009 | Akai PDP4206EA Television
Tube going out? Picture goes on/off/on/off/on/off til I go nuts!
If it does this on all inputs (cable, and dvd player) then yes you have a bad tube. If however you have cable and have a cable box it could be the box causing your problem, same with satellite, if you have satellite it could be the box causing your problem. The cable/satalite thing is just kinda a long shot. You most likely have a bad tube, just trying to give you some hope! let me know!
Tim Nolan
Sep 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY KP-46C65 PROJECTION TV
we have repaired 100s of these tv..most have a flicker issuse and it is getting hard to find replacement tubes. the cost sounds right...I suggest to invest in a new tv.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony FD Trinitron WEGA KV-34HS420 34" TV Problem:
HEY MASH-1ST ANY MAGNETS/SPEAKES OR MOTORS NEAR SET CAN CAUSE A CHANGE IN THE PIX TUBES PURITY FIELD WHICH IS WHAT YOU SAW. MAKE SURE ANYTHING LIKE THAT IS NOT PRESENT, THEN IF SET KEEPS ACTING UP YOU'LL NEED A DEGAUSSING CIRCUIT REPAIR, BEST DONE BY A QUALIFIED TV TECH.JOE TV
Oct 31, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony 34 inch Trinitron TV
uplug and open the cover and look for the red cable coming out of the picture tube. follow this red cable to a small board where you should see 2 black screws labled focus and screen. try turning these a notch and power on. it worked for some people but not for me...:(
Sep 23, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
