Question about Pentax Optio S7 Digital Camera
Optio E10 When I turn my camera on I get an error message that says "memory card error", I purchased a new memory card but still get the same error message...any suggestions? I have the exact same problem with my Pentax Optio S7. I turn on the camera and it displays the message Memory Card Error. I have tried several new cards and get the same message. There is an option on the menu to format a card, but you can't access the menu if you have the card installed. It takes great pictures without the card, but has only enough internal memory for 18 pictures.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 24, 2010
2 Suggested Answers
  • 11967 Answers
SOURCE: what dous format on pentax optio e10 mean
Format completely erases the card and optimizes the card for your camera.
Posted on May 22, 2010
I get a memory card error message on my Pentax Optio S40. I bought two new memory cards. Sandisk 512 mb. I get the same message on them. I tried formating the card on my computer. When I pit it in my...
Camera cards are never to be formatted on the computer....only in the camera. "card error" usually always means you need to format the card in the camera. This will erase it so download any pics you want to save first.
Jun 02, 2011 | Pentax Optio S40 Digital Camera
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
Mar 21, 2011 | Pentax Optio E10 Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Sanyo E10 camera will not format SD cards.
Go into the menu and find "reset"...follow the on-screen instructions. Then, with no card in the camera, find "format" and follow the on-screen instructions.
Jan 28, 2010 | Pentax Optio E10 Digital Camera
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
Jun 15, 2009 | Pentax Optio E10 Digital Camera
My camera shows CARD LOCKED
Try taking the card out of the camera and clicking the side of the card - there may be a little gap on one side of the card or a small button that you can slide up and down and then reinsert your card.
Apr 27, 2009 | Pentax Optio E10 Digital Camera
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Dec 10, 2008 | Pentax Optio E10 Digital Camera
Optio E10
Hello
Kind regards
Andrea
Oct 08, 2008 | Pentax Optio E10 Digital Camera
Memory Card Error
format the memory card by using low level format in your camera itself.
it must work. check out and reply the rating
Dec 27, 2007 | Pentax Optio M40 Digital Camera
Pentax Optio S7 Digital Camera Logo
228 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
