Question about Epson Stylus CX5800F All-In-One InkJet Printer
Printer makes all the moves,but the paper comes out blank.
The printer/copier worked fine for over a year, but recently quit putting any ink on paper. I repeatedly initiated the "clear the print-head" and "clean nozzles" options built into the printer maintenance menu, with no visible results. I also tried cleaning manually with ink-cleaning fluid and Q-tips with all the ink cartriges removed, with no results. All cartriges have been replaced with new ones, and it does not print anything. The printer obeys all the commands from the computer, and its own control panel, but absolutely no ink of any color shows up on the paper. I suspect that the print-head is somehow totally plugged, but I do not have the info as to how to remove it and not lose the proper location/timing of the head with relation to the paper/ locating ribbon.(I am a retired auto. engineer, and am quite familiar with potential damage without digging in in unfamiliar teritory).
Thanx, R.Spokas
  • 2 more comments
  • Lepapeherman Oct 28, 2008
    I have exactly the same problem, printer seems to work fine mechanically but there is no ink on the paper, I also reloaded with new cartridges, same problem.
    How do you get it to print again???
    I went to the utility tool and did cleaning and reloading many many times... same result.
    I am willing to take it apart and check the printing head but I don't know if it is possible.
    Help please
  • cobbscrystal Jan 13, 2009
    i am sorry i mean the scanner light goes off before scanner
  • rbaldasti Feb 12, 2009
    Paper feeds thru the printer and sounds like it is printing, however paper is blank???
    Anyone out there have a solution??
    Thanks, Rick
    printer looks and sounds good but paper comes out blank????
My usb epson cx5800f won't scan because the scan goes off before scanner
Posted on Jan 13, 2009
Will not print
get a new printer,you got 4 years out of it
May 19, 2015 | Kodak Office Equipment & Supplies
Help. Hi, Im JOM, my Deskjet 1280 printer feeds paper and I see the ink cartridge moving to print but the page comes out blank. What dould be wrong?
It is possible your printer is either out of ink, or it is possible the device is not making contact with the paper. Attempt to replace the ink cartridges first, if that does not work then I suggest bringing your printer to the nearest electronic repair shop.
Sep 01, 2013 | HP DeskJet 1280 InkJet Printer
Just had a paper jam, printing now coming out with blank stripes vertically on paper about 1 inch apart, help. my name is chris
I think extra ink make stripes. to remove those stripes follow the instruction:
1.open the top cover of your printer
2.find out a sponge that are in the left side of the printer bottom.
3.put off it and wash it well by using cold water. And fit it again. Then move the head left from right. Now put a soft tissue upon the printer head clining unit, then move the head again from left to right sothat printer head can reduce from ink. then move the head again and put off the tissue. Then on your printer your printer remain work.
thank you.
shohagtush
Oct 27, 2010 | Epson Office Equipment & Supplies
Paper problems
First thing you need to do Turn off the printer and Open the rear access door or cleanout area as we call that (back door) and clean all the rollers on the back. make sure also that you are using the deskjet paper and if you put 20 pages of paper on the paper tray make sure to fan it before you put it in. the alarming sounds or blinking on the printer indicates that the paper is jamming on the printer
-The ink is normal to move to center or left to right, But if you open the printer access door the ink or the printhead should stay on the middle for you to able to replace the ink cartridges and remove the printhead
Nov 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon BJC 4400 won't put ink on the paper
You need a new printhead, BC-21E, they wear out and plug with ink and the only repair is to replace the printhead.
Sep 16, 2009 | Canon BJC 4400 InkJet Printer
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
Inkworks
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
Cannon MP 830 Print Issue
sounds like your print drivers on computer are corrupted..try this link for new ones(you may need to completely uninstall the old ones, first, though).
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus CX5800F All-In-One InkJet Printer Logo
178 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
