I need a hard disk for my Toshiba Portege 7200.
I spoke to some of the authorised Toshiba resellers and they told me that I
could use any 2.5 hard drive.
So I got a Toshiba hard disk, model: mk1516gap.
BUT, my laptop doesn't even see the hard disk. : (
Can anyone help?
What hard disk are compatible with my laptop?
Any help would be appreciated.
Thanks.
BB
Rating: 0%, 0 votes
Go to Toshiba's site, and download the latest BIOS update for your machine.
Flash the BIOS with it, and it *may* solve your problem, if the drive is
bigger than your BIOS supports, or similar.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
He CANNOT get it to FDisk.
Quote "I fdisk it...and fdisk says: "no fixed drive"?"
That means the drive is not being found by the PC.
He hasn't !
Correct, so it's either not connected properly, or he needs a BIOS update.
Rating: 0%, 0 votes
Suggest a bios update :-) Oh! I seem to remember someone suggesting that
:-( Try Toshiba updates and download a Bios update for your machine:-0
BTW
I assume you have another machine:-0 So why not, throw the bloody laptop
into the nearest river :-0
HTH
CRF
Rating: 0%, 0 votes
put Dos files on it to run fdisk even though it says no drive? So that
leaves broken. New drives are rarely "broken" IMHO
A mystery, but probably easy to sort out if all info has been provided.
Going away now:-) Had enough.
CRF
Rating: 0%, 0 votes
ANYTHING to it !
It's either broken, or not connected.
Rating: 0%, 0 votes
Thanks for the reply.
Em... that's where the prob. is. : (
Fdisk just gives a message saying "no fixed drive".
Have yer got any other suggestions? : )
Rating: 0%, 0 votes
recognised and this could be the reason it is not being seen. Then needs
formatting to receive OS. That said it must be connected properly or how
could he fdisk it? As for a broken new HDD been known but same reason as
above applies.
CRF
Rating: 0%, 0 votes
Update your BIOS to the latest version - if it's a large drive, you may need
to do this in order for it to recognize the drive.
Rating: 0%, 0 votes
Use a boot disk.
Step 2:
At A prompt, fdisk.
Step 3:
Delete all partitions.
Step 4:
Creat primary partition
Step 5:
SET THE PARTITION ACTIVE.
Step 6:
Reboot with boot disk
Step 7:
At A prompt, Type Format c:\
Step 8:
Shutdown
Step 9:
Install your OS.
Oh dear, my typing hands gone to sleep:-)
CRF
Rating: 0%, 0 votes
That's the prob.!
I fdisk it...
Any other suggestions?
Rating: 0%, 0 votes
Any 2.5 Hard Drive will work fine.
Is it definately connected properly ? The cable the correct way round ?
Go into the BIOS, and set the HD to AUTO.
Boot to DOS from a floppy ( "format a: /s" in Win95/98 to make one ) and
type FDISK
Create a Primary DOS Partition, and enable FAT32.
Reboot, and FORMAT C:
Install Windoze.
Rating: 0%, 0 votes
Windows rescue floppy, (you did make one didn't you?) After creating the
partition, you format the disk, then start the loading procedure.
Post a New problem for Toshiba 15 GB Hard Drive
Email this problem
