Question about Sony Lithium Coin Battery CR2032
Battery Replacement My vechicle remote model Silencer H50T28 uses the CR2032 battery. It does no pop out easily when trying to replace it and I hesitate forcing it out. Any ideas------Thanks
    Champion:
  • 242 Answers
Use a safety pin to pry it up. It is supposed to be in tight to keep it from popping out in a jolt. Also check to see if there is any metal clip on top holding it in place. If there is, make sure you pry up on the opposite side of the battery.
Posted on Oct 21, 2008
My remote for my 1999 vw bug dose not work
The first thing to try is a new battery. Mine takes a CR2032 coin cell. Replacement isn't difficult, just pull the two halves of the remote apart; the top half with the key separates from the bottom half with the buttons, then the bottom half opens up and the battery is right there. No tools needed.
When you press a button, you should see the red LED on the remote light up. You can also take it to most auto parts stores, and they'll have a tester that will tell you if your remote is generating a signal or not. If you've replaced the battery and the tester doesn't show a signal, it may be time to replace the remote.
A replacement remote will have to be programmed for your car, but it's not a difficult procedure and you don't have to go to a dealer to get it done. An internet search should give you instructions fairly easily.
May 03, 2014 | 1999 Volkswagen Beetle
Replacement battery for 5786 taylor scale
Fixya does not sell replacement batteries.
Dec 23, 2012 | Taylor Health & Beauty
Chrysler 300M turn signals and flashers don't work
The Combination Flasher, also refered to as the combo-flasher, is mounted to the in-line bracket which is located to the right of the Junction Block. The Junction Block (JB) is located in the left endcap of the instrument panel. REMOVAL Open hood and disconnect the negative battery cable remote terminal from the remote battery post. Remove the left instrument panel silencer. Refer to Body Instrument Panel Silencer, REMOVAL. The flasher can be removed by pulling in a rearward direction. INSTALLATION Install the flasher by firmly pushing it into place. Install the left instrument panel silencer. Refer to Instrument Panel Silencer, INSTALLATION. Connect the negative battery cable remote terminal to the remote battery post.
Aug 06, 2012 | 2002 Chrysler 300M
I need to replace the battery on my Dell dimension XPS gen 4 computer. Where is the battery and what type of battery is used for replacement?
the battery is located on the motherboard it will look like a giant hearing aid battery remove the battery and go to your local pc shop or even best buy and they will have the right battery for you. Make sure you unplug the computer prior to opening it up
Apr 14, 2011 | Dell Dimension XPS Gen 4 PC Desktop
Whenever i start my computer i find my time to be 12:00 1st jan 2002 how can i set it
Hello Saifthesmart51, Hi looks like you need a replacement battery for your motherboard, after replacement, set the time in bios or in windows. The battery looks like this. CR2032 cyberdyers_4.jpg
Feb 09, 2011 | Computers & Internet
Just need a battery, where do I get one. My remote is only 2 years old, is it common to need a new battery?
Most remote batteries will last 6 months to a year for an LCD remote or a year to 2 years for a standard 1 way remote. They're common batteries that can be found pretty much anyway. Most 2 Way LCD remotes use a AAA battery and a lot of 1 way remotes use the "coin" style batteries such as a CR2027, CR2032 etc... These can easily be found and most retail stores and drug stores. Look by the hearing aid and watch batteries. Just match it up with the battery you have in there now. If the remote doesn't have a sliding cover, then use a small flat head screwdriver and look along the seam of the remote for a small notch made for popping the remote apart for battery access.
Nov 17, 2010 | Prestige Remote Start
My remote start just stopped working.
possibly a battery the battery is a cr2032 if you buy a new one it should have this number. you can also have remote checked at a autozone for free. battery is easiest thing to try. remote pops apart buy using a coin or screwdriver
Sep 27, 2010 | 2008 Chevrolet Equinox
Need help changing batteries on Wave Radio remote
Setting up the remote control
WARNING: Keep the remote control battery away from children. It may cause a fire or
chemical burn if mishandled. Do not recharge, disassemble, heat above 100°C (212°F), or
incinerate. Dispose of used battery promptly. Replace only with a battery of the correct type
and model number.
Your remote control may be one of two types. Each is identified by the way
the battery compartment unlocks to install or replace the battery.
1. Place the remote control face down on a flat surface.
2. If your remote has a slot on the back, follow step A. Otherwise, follow step B:
A. Insert the tip of a ballpoint pen into the slot. Push to the side as shown and hold. Slide
the battery compartment open with your finger.
B. Using your finger, push the tab lock to the side as shown and hold. Slide the battery
compartment open.
Setting Up
See operating
instructions for types of
battery to be used
Note: Use only a Duracell, Eveready, Maxell, or Toshiba CR2032 or DL2032 lithium battery
(available at electronics stores). If you have difficulty finding a replacement battery, contact
Bose® Product Support (see phone numbers on the inside back cover).
3. Keeping the remote control face down, insert the new battery into the compartment with
the + symbol facing up.
4. Gently slide the battery compartment closed. It locks automatically.
5. Use the supplied mounting strip if you want to attach the remote to a surface in your
listening room. Peel off the protective backing to stick one piece to the back of the remote
and the other to the selected surface.
Jul 18, 2010 | Bose Wave radio remote control - Graphite...
How to change cmos battery?
the COMS battery is part of the motherboard, in most PCs they are inserted in a removable slot, the battery is a watch cell the size of a Dime and can be replaced (the battery serial/model # may be CR2032)
In some they are fixed in the motherboard, it's hard to remove it in this case.
u need to open the PC box to look for the battery, it can be easily detected if you can view ur complete motherboard.
Jan 21, 2010 | Fujitsu Stylistic ST5112 Tablet PC
Can't remove battery of remote to bose radio/cd player (won't work)
On the back of the remote there is a small hole. You need to slide the small lock in the hole over and the battery compartment should pop open. This requires something small like a straightened paper clip. You may need to coax it a little with your finger by pushing out off the end of the remote. There is a picture of this on the back of my remote. I just removed my battery so i could replace it. The battery size is CR2032.
Oct 08, 2008 | Bose Wave radio remote control - Graphite...
Sony Lithium Coin Battery CR2032 Logo
161 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
