Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Tractor stalling My tractor stalls as soon as I release the brake/clutch pedal.
  • bpkerr Oct 13, 2008
    I cut grass for 10 to 15 minutes when it starts to cut out. I can manipulate the choke enough to get me back to the garage usually, but sometimes not. This is very frustrating when you just spent $2200.00 on the thing. I originally thought the engine was over heating, but after cleaning the air filter I don't believe this is it. I changed the fuel filter and no luck. I am leaning toward electrical. What happened to the good ol days when gas was gravity fed and all you needed was air and a spark to make it work. Any help would be greatly appreciated.
  • 16 Answers
Check wires on switch under seat
Posted on Nov 11, 2008
Have 17.5hp rider. Starts and ideals ok with brake on. As soon as brake released it stalls. Tuned up and replaced the seat switch. Any ideas?
Hi, It would be more helpful to know make and model of lawn tractor. But lets try take some steps. I assume the tractor is in neutral when started and in gear when release brake pedal? So does it stall when you release brake pedal when in neutral? If not then its not. We can start checking why. Does it stall from working the engine or just shuts off? If it just shuts off then it is a switch. If it truly stalls then a park brake is on or tranny is jammed. Jack drive tries off the ground. See if you can turn tires in neutral. If you can't look for a park brake lever. And while jacked up check all your belts. To see if any are pinched. That is another problem sometimes. The drive belt gets pinched.
Jul 04, 2014 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Craftsman lawn tractor
Really need to know if it acts like it wants to stall or if in fact when you let the pedal up it does stall ? Because they're closely related yet 2 different types of problems. One could be a safety switch problem the other could be one of a few different issues. Can you let us know if it does stall or are you pushing the clutch/brake pedal down before it does ?
Jul 13, 2013 | Garden
My MF 1428v tractor engine stalls when I put it in gear
you are going in the right direction the first switch to look at is the one on the clutch/brake pedal try and jump it with a paper clip to test it
Jun 19, 2012 | Garden
I went to go mow the lawn for the first time this season. Tractor started right up. took the deck cleaned and greased it. Went to engage the p.t.o. for the mower and the tractor stalled. Can't figure...
Hi and welcome to FixYa, I am Kelly.
The power sequence for engaging the blade deck is. Clutch brake pedal depressed, operator in seat, Enage selected and brake pedal released. When the blade enages the engine igniton kill wire is routed through the seat switch AND the PTO clutch. If either the PTO Clutch or the seat switch has a problem the engine dies. Same goes for the clutch brake pedal switch... if the clutch brake is not coming all the way up the engine will die.
If you respond with a model number (example LX2000) I can show via a manual where you need to troubleshoot using a meter.
Do a couple of good bounces on the seat, check the clutch brake pedal switch for clicks and then attempt to an engagement.
Also inspect the PTO clutch wires and connectors for corrosion.
Thanks for choosing FixYa,
Apr 23, 2011 | Garden
Craftsman Model 917.259566 Tractor starts perfectly, but stalls out when the clutch is released. Whats happening?
Most likely your seat safety switch is not working. In order for the engine to run with blade engaged, the operator present switch must be made when the brake is taken off (releasing clutch).
Oct 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Tractor stalls when engaging the clutch/brake
There is a safety switch on the clutch pedal, that's not the problem
look at the seat safety switch .
Feb 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
227 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
