Question about Panasonic Lands Phones
When the phone rings, there is a message stating if you want to make a call please hang up and try again
  • 51 Answers
Turn off the phone for few minutes and take the battery away from it.. after it try again....... it will work definitely.........
Posted on Oct 11, 2008
My answer phone messages have all been deleted. When someone rings the phone, the answer phone tells callers that they cannot leave a message, please call back later.
no phone stated.
is this and old relic answering machine
or old land line portable home hands-free phone system?
what is the name if the phone and model.#
then helpers can help.
i moved you to phones
Feb 24, 2016 | Cell Phones
Why did my phone erase my recorded message and substituted the default recorded message and started hanging up after two rings?
It is likely a power interruption caused your telephone to revert to default settings. It is annoying because you have to set it up all over again including your answer message.
Jan 06, 2016 | Lands Phones
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
Mar 04, 2015 | Panasonic KXDT343 Phone
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
Hi I have a LG optimus chic android, when I got it from my bag today the bottom 4 buttons are flashing. Nothing happens if I try to turn it on/off. how can I fix it? I called the number the handset...
Welcome to Fixya
Sound like the firmware of the phone hangs up. Try to take out the battery and leave it for 1 min. Put battery back in after 1 min then turn on the unit. If same thing will happen then you need to restore the unit back to factory state. Please take note that this will delete everything to you unit.
1. Turn it off. pull the battery out and put it back again
2. Hold the Home key and Volume Down key buttons
3. Press and hold the Power key button until the device turns on
4. Follow the on-screen instructions to reset your device
Thank you for using Fixya!
Jan 19, 2011 | LG Cell Phones
Have a new i9 3G phone, unlocked and every day at 3am I receive a message from Network Msg stating that: Please check the destination telephone number and try again. Note all national UK mobile numbers now...
The best thing to do is ring your network supplier.The message will have come from them.
They may have to change some of your settings.
They will also update your software.
Hope it helps!
Jan 07, 2010 | Lands Phones
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
Phone ringing after hang up a few second
You may have unopened voice messages waiting to be answered. If you have never set up voice message service you may need to contact your phone service provider & have them disable the service they sometimes give you as a default. Contact them anyway they will know what to do.
May 26, 2009 | Panasonic Lands Phones
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Answering phone system cannot handle nuisance calls
i have problem with my phone (TX TCA115UA B)
i can not turn on the tone regime (now is on pulse regime when i dile the number)
Feb 05, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
35 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
