Question about Dell Inspiron 2650 Notebook
Start menu keeps flashing on/off,dell laptop.
Start menu flashing until p.c.warms up.O.K. after that.Very irratating, please help.
  • 45 Answers
Hi rayo49,
Try booting in safemode. restart your computer and tap F8 repeatedly at boot up. select safemode and select windows xp.
If it does the same thing in safemode check the windows key on your keyboard. it may be stuck.
If it does not. try using system restore. start>all programs> accessories> system tools> system restore. rsetore computer to a few days back or before the problem begun
Posted on Oct 11, 2008
I want to reemove adobi flash player my pc is running slow since installing adobi
Click on the start menu (windows icon in lower left corner) then control panel. In control panel, click add / remove programs. Find Adobe Flash player and select it then click remove. It should walk you through the removal process from there.
Please leave feedback if you found this helpful. Thanks!
Mar 21, 2011 | Dell Vostro 1510 Laptop
Hi i have a dell inspirion 1525 flamingo pink, and when i start my computer it fails to start and a blue screen flashes and then it starts over again, it does this in a continuous loop please help!!
start your laptop and tap on the F8 key when you start up.
this will get you to the "Advanced startup Items" menu
select "do not auto restart" near the bottom of the menu and press enter.
This will allow the blue screen to stay up and you will be able to get the stop error code. You should be able to find a fix for it here:
http://aumha.org/a/stop.htm
Jan 19, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
The dell logo flashes then the screen goes blank. The hard drive keep flashing like the laptop is booting up okay it is a xps m140 and has vista home as a o/s
After the logo flashes, press F8, repeatedly, until a white-over-black "boot menu" is displayed. Choose "Safe Mode", to see if this "minimal" version of Windows will startup successfully.
Dec 13, 2009 | Dell Inspiron XPS M140 Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Blue Screen Comes and Computer (Dell 1525) Keeps Restarting HELP!
are you using windows? just reinstall your operating system, this may keep it back to normal
Jul 15, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell XPS M1530
On your laptop, press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware. Since this is a new purchase, call Dell about this issue and relay results of diagnostics, even if no errors are detected and diags pass.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 04, 2008 | Dell XPS M1530 Laptop
what type of laptop do you have? what is your operating system? are there any error prompt?
Oct 09, 2008 | Dell Inspiron 2650 Notebook
Blank screen with cycling colours (no BIOS; no POST)
Try running diagnostics. Tap F12 repeatedly on the dell logo till you get the boot device menu. Choose diagnostics. Go through it.
If it doesnt even pull up the diagnostics, you can follow this walkthrough from dell's website.
Oct 04, 2008 | Dell Precision M60 Notebook
Dell Inspiron 2650 Notebook Logo
527 people viewed this question
Alun Cox
