Question about Frigidaire GLEQ2152ES Electric Dryer
Zanussi Tumble dryer belt replacement
Zanussi TC450 Tumble Dryer Replacing the Belt :
Consists The Drum, The Motor Spindle, The Tensioner ,The Belt ....
How to Fit the belt ?
Is it around the Drum, Groves facing into drum and then around the grooved motor spindle ? Then the Sprung Tensioner Wheel Just Resting into the belt to take up the slack ?
Is this Correct ?
  • 417 Answers
Yes, that sounds about right.
Posted on Oct 11, 2008
Neptune dryer makes noise
Check the blower to make sure it is properly secured on the motor shaft. Also check all of the bearings: motor, tensioner pulley and drum support rollers or drum bearings. You may have to disengage the belt to check the motor and tensioner.
Oct 06, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
How do i replace the belt which has broken on my tumble dryer
Pop the top (spring clips) ... remove the front (screws) ... pull the drum out ... clean everything! ... find the belt tensioner which clips into the floor ... get a new belt ... put it around the drum ... through the tensioner ... around the motor pulley ... reassemble,
Jun 21, 2010 | Indesit IS70C Electric Dryer
How do i fit new belt to my indesit tumble dryer
its easy, firstly wrap the belt round the motor spindle, feed the belt around the drum drive as much as you can, then turn the drum by hand and it ease the belt on as you turn it, be careful not to pinch your finger.
Mar 25, 2010 | Dryers
Fit felt drum seal to zanussi td4212 w tumble dryer
I take it that the belt is ok and the drum is turning.The heater comes with thermostats fitted as a complete part.There is an overload safety thermostat which is situated inside the drum and above the door,it is held in place with a self tapping screw then prise open the plastic cover and then the thermostat will pull out,if replacing remember to refit the small gasket.Have you checked the filters and exhaust hose for any blockages as this will affect the heating.
Hope this helps
Feb 12, 2010 | Dryers
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Tumble dryer not turning with heavy load
It could be the problem. Check first to see if belt is tight enough and not slipping on drum. The spindle or axle the drum rotates on could be worn out. Try lubricating it if you can.
Dec 16, 2008 | Zanussi TC7102W Electric Dryer
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
1,496 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
