Question about Maytag PAV2300 Top Load Washer
Maytag wash mach
All cycles work except spin what to do
Will not spin out the clothes
Posted on Nov 01, 2008
I have a maytag frontload washer 2000 series that will not start spin cycle won't even try unless the washer is empty. no error codes showing, even after I do diagnostics. help...wife is miffed..
After determining that the washer is plugged in, the drain hose is free from kinks, the "No spin" option is not selected and the washer door is securely closed, the cycle should be reselected to see if the washer will spin. If this does not solve the problem, it is advised to contact a trusted repair service. Problems with the lid switch assembly, drive belt, drive pulley, drive motor, tub bearing or transmission can also cause a Maytag washer not to spin. These repairs should be carried out by a professional.
If the washer is spinning but clothes are still wet at the end of the cycle, one should ensure that the washer is not overloaded or unbalanced and that the correct wash cycle is selected. Delicate or handwash cycles spin at a lower speed, resulting in wetter clothes
Oct 12, 2016 | Maytag Washing Machines
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Maytag Neptune, no spin cycle...
http://www.neptunewaxmotor.com/
Mar 01, 2009 | Maytag Neptune Washer
Maytag MAV6000AWQ won't spin
my maytag atlantis does not spin fast enough to get all the water out.
Oct 28, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag machine not spinning
You have a stuck brake.My advice is leaving this one alone and lrt a tech. fix it.HINT:99% of this same problems your having I have fixed without replacing 1 part,so see if your repairman can do the same.This is a PERFORMA and is know way Maytags design.Except one thing ,the name on the front panel.
May 31, 2008 | Maytag Performa PAV2200
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
