Question about E-Machines eMachines Desktop PC
System restore i've been trying to restore my system to an earlier time, every time i try my computer keeps shutting down on me. i have used the system restore a few times in the past with no problems. i was wondering if there is something i can do to fix this problem? Thank You, Doug.
    Problem Solver:
  • 9 Answers
Yeah, the same with what harshit999 said, you probably need to use the Windows XP CD and boot from it, select "Install Windows", it'll bring up that Terms & Agreements document, and it'll detect your Windows, hit repair, grab a smoke or something, and it'll probablt fix it. If you still have the problem, reformat and install Windows again.
Posted on Oct 11, 2008
  • 128 Answers
First question is why are you restoring it at an earlier time? is your OS corrupted? or are you infected by a virus? if your OS is corrupted try to repair it by using your OS installer, boot from your installer cd and choose repair. if you are infected try to run an antivirus program.
  • 51 Answers
Your system 32 files are corrupted, you hav to either install another windows or repair the infected part of the files...
My pc keeps shutting down and starting up after checking the files its windows xp home
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Apr 15, 2013 | Computers & Internet
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Feb 28, 2013 | Computers & Internet
When i log off it goes into a restore program and takes at least half an hour to start
Try this, open Control Panel, Power Options, set to High Preformance, set Sleep and Hibernate to Never, use this procedure to adjust power options: http://msdn.microsoft.com/en-us/library/ms700612(v=vs.85).aspx ALSO, always shut down from the "Start" button, select "Shut down", if you use the on/off button the software "ID's" it as a crash, hence the startup error messages. Two more things, Open MSCONFIG select Normal Startup, use this procedure: http://www.netsquirrel.com/msconfig/msconfig_vista.html , Run a SCAN FILE from CMD prompt using this procedure: http://support.microsoft.com/kb/929833 Post results.
Feb 24, 2013 | Lenovo 3000 Y410 Laptop
My computer was taking a while to shut down and I eventually needed to go so i just pressed the off button and it didnt shut down properly. The next time I turned it on and tried to use my acer crystal eye...
Dear, which operating system you are using i.e (windows?) anyway if you are using windows, to fix the problem really quickly you have to restore your system to an earlier date on which you think ur computer is working fine. to restore fellow this- All program-Accessories-system tools-system restore. :)
Oct 23, 2010 | Acer Aspire One PC Notebook
My computer keeps shutting down (the internet) It
If you are using windows operating system then try to restore operating system to back date by dowing below steps.
1 Go to "Start"
2. All programmes
3. Accessories
4. System Tools
5. System Restore
6.Restore my computer to earlier time >Next
7 Select a restore poing > Next
8. After completion of restore it will rebooted.
Thanx
Jul 15, 2010 | Dell Inspiron 530s Desktop Computer...
PC does not shut down, battery remains on
hi,
try to restore your computer to an earlier time.
you can do this by clicking on start menu,allprograms,accessories,systemtools,system restore,restore my computer to an earlier time,select a date before you had the problem,then go
let it restore that should do it.
Mar 04, 2009 | Lenovo 3000 Y410 Notebook
Just bought an acer aspire ax1200-b1581a.it worked fine for a few days now it will pop up there was a problem with the internet and shut the itnernet down,it started out going blue screen and at the bottom...
I think the problem is related to virus. Try restoring your PC to an earlier date 9 a date when it worked fine). You do this from Start-> Programs -> Accesories -> System Tools -> System Restore. Select
Restore my computer to an earlier time and Click Next. A date calender will appear, select the preferred date and click Next twice. The system will automatically restart when restoration is done.
If u are not abe to run System Restore then you need to enter safe mode by pressing F8 during booting and selecting Safe Mode from the menu that appears. In safe mode you will be asked a question, you have to select no, and system restore will start
If restoring your pc does not solve the problem then you may need to reinstall your OS.
Nov 23, 2008 | Computers & Internet
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Norton not loaded purchased from internet, did not get email with produt key, i'm 79 and mest it all up, please help me. mr james monksfild, email pelican12@talktalk.com. thank you.
ø First of All Shut Down your Computer.
ø Restart Computer and Keep Tapping F8.
ø Choose Safe mode with Networking and Press Enter. (Win XP or 2000).
ø Run Windows in Safe Mode Click Yes.
ø Restoring Windows to a previous point
ø Click Start, Programs or All Programs, Accessories, System Tools, and then System Restore. The Welcome to System Restore window opens.
ø Select restore my computer to an earlier time, and click Next. The Select a Restore Point window opens.
ø Select a bolded date and a restore point, and then click next
ø (Note: - You need to choose a Date before the installation of Norton)
ø Click OK if a pop-up window about closing programs appears. The Confirm Restore Point Selection window opens.
ø Click Next. The computer should shut down and turn back on automatically after the restoration completes. The Restoration Complete window appears.
ø Click OK. The computer has now been restored to a previous time when it worked correctly.
ø (Note: - If an error message appears saying that the computer cannot be restored to the point you selected, try a different restore point)
After the System Restore is complete, and the computer starts successfully, update the computer software as follows: - 1). Update the system virus definitions. 2).Get the latest critical system updates using Microsoft's Windows update.
Once all this is Done you Need to Download and Install Norton Again.
Jul 04, 2008 | Computers & Internet
Windows vista on Accer aspire 5315 reboots over and over
Try starting in safe mode (press f8 on start up) once in safe mode use system restore to restore your operating system to a earlier point.
For XP
Start - programs - accessories - system tools - system restore.
For Vista
Start - all programs - maintenance - backup and restore center
May 17, 2008 | Acer Aspire 5315 Notebook
E-Machines eMachines Desktop PC Logo
79 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
