Question about Dell Office Equipment & Supplies
Deoo All in One 948 appears to reset continuously
My Dell All in One 948 printer appears continuously to be resetting or realigning though otherwise works normally. The realigning sound occurs every 15 seconds.
  • 2,071 Answers
I took my ink into the refill store and she steamed it for me and cleaned it up. It then worked great. It had dried ink and wasn't printing proper.
Try to check for sticky or dried ink this also cause to print intermittently and also not printing.You just cleaned it so it works normal again.
Hope it may help you;
Regards,
VOTIT
Posted on Oct 11, 2008
  • 3,940 Answers
It is abnormal for the printer to "Reset" every 15 seconds during a print job
try flashing the firmware:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R173989&SystemID=PRN_ALL_A948&servicetag=&os=WW1&osl=en&deviceid=13013&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=40&fileid=236341
See if the printer works better.
If not change, and printer is under warranty contact Dell.
  • Dell Master
  • 19,396 Answers
That sounds like a control problem.
Start unplugging power cord for ten minutes.
If the problem persist, reinstall drivers.
If that still does not work, the printer need to be inspected by a repairman.
    Genius:
  • 1,689 Answers
If the printer has the same exact status on another computer, you may need to remove the cartridges and the power cycle the printer, then put the cartridges back in.
if this does NOT happen when the printer is being used on another computer then you may need to uninstall and reinstall the printer from your computer.
hope this helps out.
How do I disassemble a Dell 948 printer?
Ron Worth,
Dell does not have any disassemble instructions for the printer. You can click the link below for viewing the online manual.
Dell 948 AIO Printer
http://dell.to/1vAFZ3R
Thank You,
Dell-Jesse L
Dell Cares
Dell Social Media and Communities
Nov 30, 2014 | Dell 948 All-In-One InkJet Printer
What ink can i refil my my series 11 ink cartrige ??? or another cartrige thats a hp or cannon or epson that will fit in my dell 948 printer
Hello. You can refill the existing cartridge without a problem. Other brand cartridges will not work as they are all programmed only to use DELL model cartridges.
To Refill the cartridge you simply need to pull the label off, Drill the Air holes out, test what colour is behind the hole by sticking a toothpick into it and inject the correct colour.
If the cartridge leaks from the print head then the cartridge has been overfilled and you need to **** out ink (half ml at a time) until the dripping stops.
The only issue with this is that the printer may not accept a cartridge that it thinks is empty, and even though you fill it, the in-built counter in the cartridge will still read "0"
Some models will print with a empty cartridge, constantly reminding you that it is empty. if you simply ignore or click continue you can keep on printing, but some models will not print at all if it thinks the cartridge is empty.
I hope this helps Regards GM
Jun 06, 2011 | Dell 948 All-In-One InkJet Printer
Can't download application 948 Dell All in one printer
You can download the application from this link
http://download.cnet.com/Dell-AIO-Printer-948/3000-2116_4-185937.html
May 26, 2011 | Dell 948 All-In-One InkJet Printer
I have a dell 948 all in one printer, clear paper jam then press check. There is no paper jam. I have follow instruction and site recommendation, ran printer software, problem still exist, please help
This is a known issue with Dell all in ones.
It's a problem with the power supply inside the unit.
If you were in the middle of a print job, though, and it jammed, do recheck as I've been caught out
with a paper jam where a tiny partical of paper was doing the jam. Look carefully before contacting Dell support.
Dec 31, 2010 | Dell 948 All-In-One InkJet Printer
SET UP DELL 948 ALL IN ONE PRINTER AND WON'T FAX BECAUSE WHEN I SET INSTALLED THE FAX I PUT IN A 1 AS PART OF THE DIAL CODE AND EVERYTIME I TRY TO FAX SOMETHING IT PUTS A 1 IN THE FRONT OF THE PHONE...
Unplug the printer from the PC.
Uninstall the printer, reset the computer, install again the driver and connect the printer again, then configure correctly the fax.
Done.
Thanks.
Dec 11, 2010 | Dell 948 All-In-One InkJet Printer
Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
Jan 17, 2010 | Dell 948 All-In-One InkJet Printer
I am using a lexmark replacement carteridge for dell 948 as per my computer store manager. The carteridges are not acceptable and I continue to get the error message to replace the carteridges
I would try doing a hard reset on the printer, I am not sure how to do so with your specific dell but it can be found at support.dell.com, just enter the service tag for that printer, and you would have to search for that info there, dell has excellent phone support so you can contact them as well.
If the hard reset does not work, I would try reinstalling the software for the printer.
Apr 24, 2009 | Computers & Internet
I need a picture of the refill holes on a series 11 Dell color ca
Remove the top before refilling.
Otherwise you risk that the colors get mixed.
That happened to me when using holes drilled from the top.
Apr 22, 2009 | Dell 948 All-In-One InkJet Printer
Printer 948 false paper jam
Tonight, I fixed my neighbor's Dell 948 printer with false paper jam.
After you lift open the top, look below the shiny bar that the Print Head slides left/right on. You'll see a row of 8 tiny rollers. In between the middle two rollers (rollers #4 and #5 from the left), look for a small plastic tab sticking up between them. Touch this tab with the tip of a ball-point pen to see if it pushes down. If it does, then push the "checkmark" button on the control panel.
That's what I did to fix my neighbor's printer.
Sincerely,
John
Jan 05, 2009 | Dell 948 All-In-One InkJet Printer
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
