Question about Panasonic Televison & Video
I have a panasonic th-42pwd6 and everytime i turn it on it will be on for a second or so and then go to some kind of standby mode and the green light turns red and starts flashing. if you have any ideas of why this is, it would be very helpfull
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
  • 2920 Answers
SOURCE: Colour keeps changing from blue
take it to a shop and have them look at it to see what they say.
Posted on Dec 07, 2008
smartr10U
  • 1305 Answers
SOURCE: paslode im350 has indicator light flashing red/green
The nailer’s electrical system has gone into overload protection. There may be something wrong with the fan motor or the wires going to the fan motor. Remove the cap and grill to inspect the red and black fan motor wires. If the wires are pinched or broken, that may be the problem. It may also help to disconnect the small white connector on the wire assembly that goes to the motor and then reconnect it.
Posted on Jun 23, 2009
  • 1348 Answers
SOURCE: When i on the tv by remote the red standby light
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Posted on Jul 08, 2009
Television will not stay on. Runs for 5 seconds then goes into standby mode.
Modern Flat Panel Televisions these days are really just computers inside. The Switch Mode power supply has the ability to sense faults & over current draw. So... there really isn't much the average person can do to fix an electronic problem.
The usual problem is overheating, bad connector problems & electrolytic capacitors leaking or popping. If you don't have the skills to open & look for problems then you will have to take it to a tv electronics guy.
Cheers
Feb 21, 2015 | Panasonic Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
I have a Panasonic Plasma, believe model TH-42PWD6 and a separate Denon tuner. For a while the colours have been splitting into mostly green and purple. If I flick between DVD and TV it eventually resets.
I had a similar problem with the blue tint going away. I solved it by replacing the terminal board with a new component board I picked up on eBay. You can also use the PC input with a D-sub connector using a component cable adapter.
Sep 14, 2010 | Panasonic TH-42PX500U 42 in. Plasma...
The "on" light is always green, even if turned off. Why?
It occurs when your wii in the Standby, but WiiConnect24 is enabled with Standby Connection is enabled. the content can also be received when the Wii is left in standby mode.
WiiConnect24 can be turned on or off via the setup setting. While the console is in standby, the power LED indicates the current status of the standby connection,
  • Red indicating Standby - wiiConnect is off,
  • Yellow indicating Standby - Connect mode is on. If you hold the power button for 3-4 seconds, the Wii goes into standby mode with Standby Connect off. and WiiConnect24 will not operate until the console is turned on.
  • Green ...
Jan 18, 2010 | Nintendo Wii Console
Sagem 45 inch rear projection tv keeps switching off
It is most likely some bad capacitors on the power supply board that are causing it to go into "safety mode" and shuts it down.
Jun 14, 2017 | Panasonic TH-50PV30 50 in. Plasma...
STANDBY MODE FOR PANASONIC FLATSCREEN TV TH-42HD6
Your TV is in protect mode. A problem was detected and the set shutdown. Is there a pattern to the blinking?
Dan
Mar 21, 2009 | Panasonic TH-42PHD6UY 42 in. HDTV-Ready...
Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Nov 26, 2008 | Panasonic TH-42PHW5 Television
Oct 07, 2007 | Televison & Video
Televison & Video Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
