Question about Sony Playstation 3 (PS3) Console
Red light comes on but the shuts off?
Hi, i know there are afew problems with the power lights going from red to green then yellow then flashing red, unfortunatly mine doesn't do this. If you plug it in the red standby light comes on, but as soon as you press the power on it clicks and all lights go off as if the power unit has tripped out? After this it will take 5 mins of leaving it off before the standby light will come back on. I have tryed a good power unit and the same happens, no visable signs of faults on the boards, heat sink seems ok. Do they have a temprature sensor somewhere that could be faulty?
  • 3 more comments
  • kirkyboo143 Oct 12, 2008
    mine will cut on and then cut off with the red light flashing and i cut it off and it does the same thing over and over when it does come on for a minut it will frezze up
  • slickbb4 Oct 12, 2008
    Yeh i was hopeing that would work but unfortunatly as soon as the on button is touched the power trips out so it wont even let you hold it on until the second beep, it's looking like the prossesor on the motherboard has burnt out or the temprature sensor in it has failed, thanks for the reply.
  • chevyxtreme0 Nov 26, 2008
    its the same problem will not start up
  • Anonymous Nov 26, 2008
    playin ps3 for about 30mins then it just cut out .red light was flashin pushed main button and it stopped so went to turn back on and yellow light came on the back to flashin red one .any ideas. and if i have to send back to sony how much will it cost or should they fix it for free
    playin ps3 for about 30mins when it cut out on me and red light was flashin pushed main button and it went to standby,pushed again to start it and yellow light came on then went to flashin red again.any ideas.and will i have to pay for it or will sony or place i brought it from have to .thanx for the help peeps
Mine did that and it really pised me of, sony told me to turn the power switch onthe back of the console on, when the stand by light comes on to push and hold the on button for at least 3 seconds until you hear a second set of beeps. This however didn`t work so I sent it back to Sony Australia and got it fixed up no worries.
Posted on Oct 12, 2008
Just the power light comes on
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Dec 02, 2012 | Zanussi FJS1225W Front Load Washer
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
The unit will power on briefly, the light will change from red to green, as the drive starts to spin. within a couple of seconds it shuts off and the light flashes yellow with 3 quick beeps, then flashes...
The yellow light you're referring to is the 360's evil cousin, the "Red Ring of Death". The best information I can provide you comes with some handy video tutorials but will require that you open up your PS3. This will also void the warranty so if you aren't sure what you are doing, call SCEA instead. Their number is 1-800-345-7669.
If you are comfortable with doing this yourself, here is the URL:
http://playstationlifestyle.net/forums/showthread.php?t=2376
Jan 02, 2011 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Will not turn on after charging
Sounds like it's time for new batteries.
Jul 18, 2009 | Jet 3 Ultra Power Chair
When turn on my console the green light comes on
give it to sony service and it may be problem with your power adapter
Mar 04, 2009 | Sony Playstation 3 (PS3) Console
How to fix blinking red light on my ps3?
You should open up the PS3 and use compressed air to dust it off. Take a look at the thermal paste to make sure it isn't dried up! PS3 Flashing Red Light The Ultimate Solution
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Anyone know
Usually this occurs when the Convergence ICs go bad along with some chemical fuses mounted on the deflection board. E994 usually blows along with the Horizontal out transistor going bad. This transistor, I believe is Q777 that usually goes bad. The fuses are either tiny little yellow fuse with a red band or green with a yellow band depending on your model number
Jul 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
