FixYa.com
Tags:
Toshiba for T4850 Sound Card
Need to bypass password on toshiba t4850 laptop..?? (by 3 users)
By Riddle - usenet poster
Hi there...I have a bit of a problem
I have aquired a Toshiba t4850ct laptop, this unfortunately hasn't come with
any floppies..ie boot up.
The prob. is when I boot up it requires me to input a password, this I
obviously don't know.
I have tried to get into the bios by pressing esc and f1..but the password
request overrides this...I wonder if anybody could help...thanks
Michael...South shields...
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by yamisilva, posted on Dec 19, 2007
Well my toshiba laptop it is a satellite A135-s2276 and it is asking me for a password to log in
Comment by Guest, posted on Dec 16, 2007
i forgot my HDD password (tecra m40
Best Solution
posted on May 27, 2006
FixYa! (100)
Bouncy
Bouncy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
rubbish. either remove the cmos battery as suggested or make the toshiba
password dongle. plugs into printer port, bypasses the password. mail me
privatly and i'll send you all the details you need.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
FixYa! (100)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
In that case your machine is not one of the T4850 or any other EEPROM based
Txxxx series machine. It's either something like a 1950CT which just needs
the CMOS battery removed, or one of the newer machines, e.g Satellite 110CT.
To re-emphasise, this machine does need either a new EEPROM, or a copy of
the engineers disk to remove the password.
Matthew Saxby
Solution #3
Helpful (85)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
BEGIN PGP SIGNED MESSAGE
Hash: SHA1
wrong - Rob _is correct_ on this.
The T4850 is one of the few machines which the dongle and keydisk do
not work. To remove the password you need to either send the machine
back to Toshiba (not one of their dealers) who have an engineers disk
to unlock the machine (The engineers disk is not the same as the
keydisk and only Toshiba have a copy). I had to send three T4900CT
machines to Toshiba a few years back. It cost ??50 per machine,
although now that the machines are so cheap it's debatable whether or
not its worth it.
On none of the 'modern' (ie. fast 486 and above) will removing the
CMOS battery work and on most of the branded machines this holds true
for supervisor/admin passwords at least.
Hope this helps,
Matthew Saxby
BEGIN PGP SIGNATURE
Version: PGPfreeware 6.5.3 for non-commercial use <#>
iQA/AwUBOenxkGKnPVzFFnuaEQIAkwCgvTfErqhZCzvCcmy/kdZcX59WmkEAoIe9
+oJPQCAD7kjwQrY+R5tD/S6R
=x7on
END PGP SIGNATURE
Solution #4
Thanks for Trying (70)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
Get a PICO, they've not got a dongle, they do work well though.!
Solution #5
posted on Jun 13, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
you have to give up and bo on buy one new DELL laptop
Solution #6
posted on May 08, 2008
Not Rated (0)
zmakki
Rating: 0%, 0 votes
hey all,
you can reset the bios password without to remove the battery from your Laptop, open the back cover of Memory and then remove the memory unit and then remove the plastic stickers and then you have like reset space called J1 just do it
Solution #7
posted on Jan 04, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
fucking assholes all of you the password is stored in eeprom memory thus removing the battery wont do anything other than waste your time fucking knob jockies try studying more than that stupid A++ that all you wankers seem to understand..the password can only be removed by Toshiba "Engineers" asuming thats what they call themselves these days (DENEL WEAPONS FIRMWARE ENGINEER)
Solution #8
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
bloody odd that cos my laptop was password protected and my dongle i made
knocked it straight off.
So no, it wasnt rubbish it all!!!!!
Ahh, smug mode.
Also speaking to a toshiba service centre confirms this.
Solution #9
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
Your right mate, it was rubbish you don't need to replace the system board,
forgot to refresh my memory but now I have and it seems you were
talking more rubbish than me the T4850 range was designed to be extra
secure and the password cannot be disabled using the Toshiba loopback
(Parallel) and the remove the CMOS battery is crap anyway - read the snippet
from the Toshiba Support website below:
GENERAL - Password Deletion
The password protection on the
T4500 / T4500C
T4600 / T4600C
T4700CT
T4800CT / T4850CT
T4900CT
T6600C
is designed to be as secure as possible. Therefore, once a power-on password
has been set in the PWSETUP utility, it cannot be changed by any
unauthorised person.
This means that if users forget their password or an unauthorised person
tries to bypass an existing password there are no bypass routines available
to them.
If users forget or misplace their power-on password, they must send the
machine back to Toshiba via their authorised reseller. The reseller must
call the Technical Support HelpLine to book the machine in as a CHARGEABLE
REPAIR with a Purchase Order number (the 'repair' will be charged at normal
hourly rates for labour with no parts replaced). Toshiba will then disable
the password and return the machine to the reseller.
Note: Users should be strongly advised to create a 'master password' which
can be used in emergencies if normal user passwords are forgotten.
Access to this password should be limited to the least possible number of
people and it should only be used as a last resort.
rubbish was it ?
Rob
Solution #10
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
Is it the BIOS or Windows Password you mean?
Jhimmy.
Solution #11
Not Rated (0)
Phoebe
Rating: 0%, 0 votes
how exactly did you come by this lap top off the back of a lorry?
Solution #12
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
On the 4850 you will not be able to bypass the password, replace system
board
Rob
Solution #13
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
You'll need a tech. here...Open up the Laptop and remove the CMOS batt. for
a few seconds.
"I don't cheat to survive. I cheat to LIVE!"
- Alceryes
Can you Help with these Sound Cards problems?
Sound Cards
uc-280 speakers
can't get the speakers to work... Answer This...
Sound Cards
Compaq presario C773TU Sound...
Compaq presario C773TU Sound... Answer This...
Sound Cards
sound
the sound volume is not loud... Answer This...
Sound Cards
No stereo sound.
I had to reformat my hard disk,... Answer This...
Sound Cards
pls i need ur help
my system has a slifht problem... Answer This...
Repair Service
Find Sound Card Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
