Question about Intel DG31PR Motherboard
Bios Can't Memorise Seting.
Bios Battery Ok. I properly Setting Every Option t.e Time,Bobotting,Power But Bios can't Save. when Start Computer Apper a Option F1. Please Solve This ProblembKindly.
    Scholar:
  • 59 Answers
When you enter your bios and make changes you must save those changes before you exit normally this by pressing f10 wich will save the bios and then exit, and reboot the computer.......
i hope this is what your looking for.......if not please clarify the question for me.
Posted on Oct 11, 2008
HOW TO REST MOTHERBOARD AFTER CHANGING BATTERY
If you changed the CMOS battery you in effect reset it. On boot up, go into the BIOS setup and check all settings. Even if you don't change any of the BIOS settings, save them as if you did and it will reboot. Should be OK then.
Apr 02, 2015 | Computers & Internet
What is BIOS?
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS if you have changed any of the BIOS settings by mistake you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer.. this will reset your cmos
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
b>
Jan 03, 2013 | E-Machines eMachines Desktop PC
How do i restore factory settings
To reset you Motherboard the are two options:
Option 1: Software Reset via CMOS:
Access you computer's BIOS settings , usually when starting the PC the BIOS will state the Keyboard key to press to enter setting (i.e on a Dell press F2 to enter settings, HP it's F12 etc...)
Once within the BIOS settings scroll though the setting and pages and you will an option to "Load Default Settings" , select and Save (you will asked to save any changes on exit, almost all BIOS's Save and Exit setting with the F10 key.
Option 2: Physical Rest of the Computers Motherboard settings:
you need to remove and replace the CMOS battery on the motherboard, this battery looks very similar to a watch battery and usually rate for 10 -15 years battery life, it's role is to trickle fee power to the BasicInput/Output System (BIOS) Chip that all computers contain.
Requirements:
* Acess to the Computer , may require a Phillips Head Screwdriver
* A small flat bladed screwdiver or a pair of tweezers
* A steady-ish hand !
Open the case and locate the small round silver battery on the motherboard, remove the battery (may require releasing a small srping catch), relax for 3 minutes , replace and when the computer is restarted the BIOS and CMOS setting are at factory default.
Remember you will need to reconfigure you BIOS for :
Time/Date
Boot Order
and possibly other settings.
This is a situation where the Motherboard Manual can be a useful asset.
May 06, 2011 | Computers & Internet
My pc automatically get start on plug on .and then it suggest me to press F1 to Continue. when I do this it takes incorrect date and time how to restrict it.I want to start it with start button on cabinet
There can be many reasons...
  • Your BIOS setting is not correct.
  • CMOS battery is down(Most probably).
  • both
You can open the BIOS setting page by pressing keys like DEL, F10, etc. depending on your system's manufacturer at computer startup(post screen). There are lots of wakeup options check them properly.
One of the option is "Restore last state of power Button on failure" which can turn on your computer without touching the power button. you should check these options.
And it suggest you to press F1 because your system's date/time is not configured properly. You can also set Time/date in BIOS also.
If your BIOS Battery(CMOS) is not weak or dead then after setting these values your computer should start properly.
And if your BIOS battery is dead then all the settings will be lost(date/time etc) after a restart and you will face same problem again...
Try changing the Power-button option and Date/Time in BIOS and see if problem persist....if yes then you have to change COMS battery that is on your Motherboard.
Sep 22, 2010 | Computers & Internet
Where can I ajust the clocktime in bios?
right click on the time and select "Adjust Date/Time"
Then Click the "Internet Time" tab at the top.
Click "Change settings..."
Select "time-nw.nist.gov" and Update
I hope this helps.
May 31, 2010 | Office Equipment & Supplies
Bios time and boot problem
friend there can only be 2 probs
1. you mb bios cell is dead, so just replace it
2. ur bios is not saving at all, get ur bios updated by a mb technician
thanks
Apr 11, 2009 | Dell Computers & Internet
Bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Ian
Mar 09, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Asus motherboard bios version1104
Whether it shows your cmos checksum error press F1 to continue or f2 to load default.? If this is the problem than kindly switch off the system check for the cmos battery and change the cmos battery and set the date and time properly in the bios and save it by pressing F10.This will resolve your problem.and if not than check the jumper setting on the motherboard is it set to clear cmos and if so kindly remove and set it properly to adjacent jumper ok. Have a nice time.
Dec 04, 2008 | Computers & Internet
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
BIOS PROBLEM
Actully you are not selecting the reall speed of CPU thats why it asks. Its better to use the default setting of your BIOS as it was provided by company as per your specification.
Thanks
Iqbal
Mar 09, 2008 | Computers & Internet
Intel DG31PR Motherboard Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
