Question about Dishwashers
I have a Necht dishwasher. The dishwasher door does not close therefore I can not get it to operate. Someone came to have a look at it and they said that it needs a replacement for the door latch. The problem is I do not know where I can find this replacement for this brand ( Necht). Can you tell me where I can burchase or order it from? a website or a shop.
  • 417 Answers
Depends where you are located. Try google .com and search for Necht.
Posted on Oct 11, 2008
Please, can you tell me where to find instruction manual for Necht WQP8 - 9325?
Dec 01, 2017 | Dishwashers
Where can i buy a new door latch for my necht dishwasher
Get the name of dishwasher and serial number and call a appliance dealer near you and order part thru them,you may need to take off and take it to them to match up in their part book to make sure it's the right one.
May 29, 2017 | Dishwashers
Dishwasher door wont close
you did not giver manufacturer, model and year, it is not possible therefore to give detailed info what to do - for future references - do provide these "little" details, telepathy is overrated and usually do not work...
from your description can be several causes of that, one of them is motherboard fault, another will be actuator and third can be mechanical fault within lock or with hinge... make your pick...
Feb 07, 2015 | Dishwashers
My necht wqp12-9319 dishwasher is showing an error code of E4 and the drain pump is running all the time even with the door open
Most likely the flood switch has tripped. This means there could be water leak in the dishwasher.
Pull the dishwasher out after turning off the power and water connections and tilt from side to side.
Wait a little and try and run again. If this fixes the problem then you have to find the source of the leak. Mostly a door seal problem which causes water to get to the motor chamber.
Jun 17, 2011 | Dishwashers
D/w doesn't dissolve deterg. & therefore not washing dishes
Do this test:
-Upgrade to a name brand detergent like Cascade or Electrosol.
-Do not over fill the dispenser cup
-Do not place large items near the door/near the dispenser cup.
-Make certain that both spray arms can spin freely after you load the dishwasher but before you close the door to begin the wash.
Please report back what you find, OK?
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher won't start
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
May 16, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
The door latch appears to be in the closed position and therefore you cannot close the door.
cut the power to the unit and see if it releases the locking mechanism,then its in the control board circuitry that keeping power on it all the time as if in use with the door closed
Mar 19, 2010 | Candy A8001 Dishwasher
Door lock for dishwasher
Hi Sylvia, did u manage to find a supplier ??? as my aunt now has this problem. Please get back to me if u can help, it would be much appreciated !!!!
Oct 20, 2009 | Haier Dishwashers
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Dishwashers Logo
227 people viewed this question
Top Dishwashers Experts
