Question about Canon PIXMA MP170 All-In-One InkJet Printer
Canon Pixma MP130
Wate ink absorber is full an dhter eis no information on what to do to empty it! Help, please.
    Problem Solver:
  • 19 Answers
Open the printer carefully, and remove the pad that is located in the base of the printer... You can wash then dry it and put it again... It works...
Posted on Oct 24, 2008
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full How do i empty it
You can't empty that one, you need a shop to replace the pads which are under the printer, and they can reset the waste ink counter at the same time.
Sep 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Absorber nearly full. canon PIXMA MP130. How do I empty it?
To Clean Waste Ink Absorbers:-----------------------------
  • Open the cover ( the cover you open to replace the catridges ).
  • Locate the Waste Ink Pads which are situated in the or under the Catridge Slider.
  • Dry up Waste Ink Pads ( You should wear Gloves when holding them).
  • Rinse the pads with Alcohol and make them dry.
  • Replace Pads .Then Set them. Make sure they are sitted properly.
Thank you Sir, I hope I helped you. Have a nice day.
Sep 21, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Wate ink absorber is full on canon pixma mp130. i have no manual
There is no replacement absorber for your machine. During warranty Canon would replace the whole printer, after warranty, you toss it and buy a new printer.
Jul 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
My printer is canon ip1980." ink absorber is almost full
My inkjet printer no. IP1980 is ink absorber is full. Please help me.
Jun 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
The ink wate absorber is full
You may find the instructions here if you search through the forum.
http://www.fixyourownprinter.com/forums/inkjet
there is usually someone who has had the same problem.
Cheers
May 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP130 all in one printer
do you have a manual on this printer?
also, see this for more assistance
Apr 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
