Roland Micro Cube Battery Powered Amp W/effects & Tuner Logo
Steven Mauch Posted on Jan 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roland Micro Cube Amp fuse blew out. How do you fix it?
I was playing guitar and right in the middle of playing, the amp suddenly turns off. After that, it wouldn't turn on. I believe I blew a fuse. Any tips on repairing the fuse? I'm trying to fix it my self. So please be specific on what to do. I appreciate anyone's help. Thank you!
Anonymous
Level 2:
New Friend:
  • Expert 132 Answers
  • Posted on Jan 11, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
132
Questions
Helped
49605
Points
354
Have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Roland Cube 30 Bass Amp won't turn on?
1. Check the power cable and ensure it is securely connected to both the amp and the power outlet. 2. Check the fuse and replace it if needed. 3. Check the power switch and ensure it is in the correct position. 4. Check the battery (if applicable) and replace it if needed. 5. If the amp is still not turning on, contact Roland customer service for further assistance.
2answers
Why would my iron heart Lainey 212 combo amp combo be blowing fuses?
Because some component in the amp is failing/failed and drawing too much current. The amp needs a repair shop. Poking around without knowing what you're doing can expose you to leather voltage. Don't do it.
Roland micro cube fuse replacement
If the fuse blew, it is for a reason requiring repair. Troubleshoot and use a 40 watt lamp in series to limit current until cause of fuse blowing is found and repaired.
I have a Yamaha GE 112c2 guitar. One day I was playing, and the sound suddenly cut off. The guitar was plugged in, the amp was on, and the volume was on high. I can't find a wiring diagram, or anything...
Sounds like the amp (or speaker) blew. Do you have anything else you can plug into the amp to test? If possible use a different cord to preclude that as a cause, too.
I am getting buzz, ******* noise with low Aon E string and open A, also the A on the 12th fret, its just below a, a flat is also causing a buzz, the micro tune is new, i had played with a friends over the...
This sounds like fret buzz caused by improper setup of the guitar. Likely the intonation needs to be set and the string height... possibly a truss rod setup as well. Take the guitar into a shop for setup unless you are adept at setting. There are a couple videos on guitar setup on YouTube, however do NOT try a truss rod adjustment yourself.
Roland micro cube dosnt power up
Check the fuses. There is probably one on the outside of the amp and some inside the circuit board.
2answers
Schematic
Heree is link to cube 40... not sure what the XL suffix gets you...
http://elektrotanya.com/roland_cube-40.pdf/download.html
Scroll down to the little link "Get Manual" and click on that.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
