Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo Pro V2010 base removal
Trying to remove the base from my Amilo Pro V2010 to replace the inverter. I've removed all the obvious screws in the base but it still wont separate. Any ideas, suggestions or knowledge of where the 'hidden' clips are?
The inverter is in the laptop screen, not the base.
1 remove the screw covers and then the screws surrounding the laptop screen
2 gently prise the screen bezel away from the screen, best done when the laptop is opened out almost flat
3 the inverter is at the base of the screen, gently unscrew and unclip the inverter from the LCD screen
4 take replacing the inverter to make sure all the leads are safely housed
5 replace screen bezel and away you go
Posted on Oct 27, 2008
Where i can buy, power socket for my amilo pro v2010?
Just one example,
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Where can i find the free complete drivers for fujitsu siemens amilo pro v2010?
Type in your browser Fujitsu Siemens support.
One heading will say support Fujitsu and under it the first heading will say downloads click it.
Where it says
Please enter either the Serial-/Ident number or the product name enter the ID that is on the base of the laptop all the drivers for that model will be listed and available for free download.
If the code on the base of the laptop is unreadable use the next box down
First rectangular box in the drop down menu select notebook
Second rectangular box in the drop down menu select AMILO Pro
Third rectangular box in the drop down menu select Amilo proxxx
Fourth rectangular box which says please select product in the drop down menu select V2010
Select your operating system and all the drivers will be listed in categories which you can download free of charge.
Hope this helps.
Sep 12, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How can i locate and change my cmos battery for laptop fujitsu siemens v2010 pro
The above post sounds simple it is Not, the COMS battery in a Fujitsu V2010 is located just to the left side of the left hand mouse button,( just about where it says AMILO Pro) (under the top cover)
(All power off battery out)
To get at it you remove all the base cover screws including the four on the back edge.
Turn the laptop over and remove the power buttons plastic strip by levering upwards between the gaps that are to the left of the Num Lock key and the right of the Esc key, (use a very thin screwdriver) or slide a screwdriver between the Num lock key and cover leaver upwards, then do the same at the Esc key side, the four retaining lugs are left and right of the cover.
The screen should be laid flat as you do this or you will rip off the keys.
Unscrew the wrap over bracket (right of screen) that holds down a thin black cable.
Pull upwards (carefully) the three connectors in the two recesses below it. (Two in left recess one in right recess)
The cables in the right recess are held down with a strip of black tape remove it and remove the cable from the retaining lugs.
Remove the keyboard screw and push slightly towards the screen to get at the retaining strap and remove the strap by levering the lugs upwards on both sides, put the keyboard to one side.
The wireless card cable is slotted in a channel lift it out. Then unclip and lift out the card still attached to the cable.
Remove the left and right screen screws and carefully lift upwards and remove the screen with the wireless card still attached, put the screen to one side,
Remove the four RAM cover screws and lift off the cover put to one side.
There are 3 tiny screws at the back that are just under the screen location remove them, the last screw is just under the key board in a deep recess remove it.
Finally lift the top cover up slightly and push slightly towards the screens location as the COMS battery is attached to the mother board at front left. (Unplug it)
Work very carefully making sure you do not miss any screws, if it will not come off you have missed something. CHECK.
The cover should come off without any resistance.
The screws are different sizes apart from the base cover screws,( TIP) tape a wide strip of cello tape sticky side up on your work bench and group the screws on it marking with felt tip where the were located.
The wires on the battery are RED and BLACK
Leaver out the battery it’s held firmly by a sticky pad and change it (the wires come attached to the new battery. (Battery VARTA CR2032 3v 0405)
I am writing this from memory but I don’t think I have missed anything, remember if it will not move do not force it LOOK. (Something’s can be done not exactly in the order I have tried to explain it)
Replacement is the reverse of removal.
One site I was looking at wanted £45 for changing a keyboard, that’s a real rip off.
Hope this helps if in doubt take it to a shop.
Best of luck. teastheword find me on E Bay.
Jan 09, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Replace laptop screen
STEP 1.:-Turn off the laptop and remove the battery.There are no screws securing the screen bezel. Start separating the screen bezel from the display cover with your fingers.
STEP 2.:-Continue removing the screen bezel on the top.
STEP 3.:Remove bezel from the hinges.
STEP 4.The screen bezel has been removed.
STEP 5.:Remove six screws securing the LCD screen assembly.
STEP 6.:-Separate LCD screen assembly from the display cover.
STEP 7.:-Place the LCD screen assembly face down on the keyboard. Now you can access the back side of the screen and disconnect cables.
STEP 8.:-Disconnect the video cable connector from the LCD screen controller board.
STEP 9.:-Parts of the video cable could be glued to the screen. Unglue the cable.
STEP 10.:-Disconnect cable from the inverter board.
STEP 11.Remove the LCD screen assembly.If you are replacing the LCD screen you’ll have to transfer mounting brackets from the old screen to a new one.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
How to change and upgrade the memory Fujitsu-Siemens Amilo Pro Fujitsu-Siemens Amilo Pro V2010
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
Nov 18, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amillo pro 2010 screens gone black tried new inverter still no good cleaned ram no good the xp pro disc is off this laptop but got invalid message when reinstalled the screen went blank two days later cant...
Try useing external monitor?
Dumb Question.
Try switch monitor button? Fn + F5 (together) usually
Hard way,
Remove hard drive, maybe even CD Reader, Floppy.
Power on system
Oct 02, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Keyboard replacement instructions for fujitsu siemens amilo pro v2010
The keyboard removal process is very similar to many other laptop brands.
1. Remove screws securing the keyboard.
2. Remove keyboard bezel.
3. Unplug keyboard cable from the connector on the motherboard.
A word of caution. Be very careful with the connector on the motherboard when you unlock it If you accidentally break the connector, you’ll have to replace the whole motherboard.
You can even try this site
or this site,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
It is not your model but it will give you an idea.Just keep pressing "next"
Hope it helped.
Aug 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Opening the case to expose my memory?
I went on the Internet and found a very,very helpful site, for free!!! Thinking it was difficult, it only took 10min. to do everything. Know I would like to change my Hard drive? That's gonna be a nice obstacle. I'm hoping that web site has that info. as well.
Apr 17, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Memory uprgrade
You have to remove the keyboard, under the keyboard to the left is a heat shield (silver metal cover), remove it. Your ram is located there. Just take your time and remember where the screws go.
Jan 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Power pin
I've found instructions with a diagram about how to open it up (for a memory upgrade). The directions are in German, but the pictures should still be useful.,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
Basically, the directions
1. Shutdown the laptop, turn offthe main source on the wall, unplug and
disconnect the power supply fromthe laptop.
2. Discharge yourself by touchingthe unpainted part of a PC or a radiator.
3. Remove the battery from thelaptop. (Shift the battery lock and pull
battery pack out.)
4. Remove the control Panel (usea razor or a flat butter knife ) push the
knife downward gentle and tilt itabout 30
outward to release clips and
left panel. Repeat the process onthe other side till the entire panel is
freely removed
5. Remove the panel to expose thesingle screw that secures the keyboard.
6. undo the screw to free thekeyboard and lift the Keyboard gently
7. Undo the clip that holds thekeyboard connector Ribbon in place this
would completely free thekeyboard. Remove the Keyboard. To unveil a
metal plate
Nov 10, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
416 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
