Question about Canon PIXMA MX700 All-In-One InkJet Printer
MX700 You mention a "resume" button on the MX700. I can't find this. I cannot get rid of the 6502 error... any idea???
  • Anonymous Nov 12, 2008
    error code 6502 appearing on lcd screen - don't know what this code is or how to fix it
  • SDFitz Jan 04, 2009
    Somethign to do with the print head and one of the ink cartridges. When I replace the ink cartridges I can actually get the printer to function in a normal way. When I use all four cartridges, I get the 6502 error.
  • 4,041 Answers
Solution:
1. Unplug the printer.
2. Remove the faulty Cartridge
3. Plug in the printer and press and hold power button
4. Keep it held down. Press Resume twice, and this should reset the fault.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Error 6502 came up on my viewing box and I cant get it to clear. I dont know what caused it exactly. I had a paper jam and I pulled the paper out of the rollers to clear it now I have error 6502 and I dont...
Pls do the following :-
Error code 6502 The Error code 6502 can occur in the printer as a result of ink tubes caught under housing and jammed the print head against the right hand side of the printer. The printer is unable to do anything now and it will give an alarm light only. To fix this issue, you need to unplug the printer and then plug it back. You need to press and hold the power button of the printer and click the Stop button twice. You can then release the Power button and press Stop button for four times. The issue will be fixed and you can start your print jobs.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX700 Office All-In-One InkJet...
Error code 6502
First, with the printer unplugged, remove the ink cartridge on the right.
Next, plug in the printer and press the POWER button. Do not release the POWER button and press the RESUME button twice. Now release the POWER button ,press the RESUME button 4 times .
The beeper may sound once. Unplug the printer. Plug it back in a power it up. This should work.
May 12, 2011 | Canon MX700 Office All-In-One InkJet...
Installing new ink, getting code 6502, can u please help
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Mar 07, 2011 | Canon MX700 Office All-In-One InkJet...
Canon mx700 has a code 6502, what I have should?
code 6502 Please do the following:
1. With the printer unplug, remove the ink cart to the right ,
2. Plug in the printer
3 Press the POWER button and do not release the POWER button
4. Press the RESUME button twice in succession.
5. Now release the POWER button
6. Ppress the RESUME button 4 times.
The printer may beep. Unplugg the printer, reinstall ink and plug it back in. This should clear the issue.
All the best Pineworks
Apr 27, 2010 | Canon MX700 Office All-In-One InkJet...
Canon mx700 error 6502 Problem
Hi there
Solution:
Feb 25, 2010 | Canon MX700 Office All-In-One InkJet...
I have a cannon mx700 and I changed the black ink cartridge. I keep getting the 6502 error. I have followed the instructions to clear it, but I can't get it to clear. Help
Ok try this may help.
Solution:
Feb 12, 2010 | Canon MX700 Office All-In-One InkJet...
Error code 6502 on my canon printer
How to RESET the Error code “6502” for CANON ip4300 ?
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWERbutton ,and then press the RESUME button twice in succession .Nowrelease the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,afterthat reset the printer electronics ,open the printer and this processis finished.
Sep 17, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Error 6502
1. With the printer unplugged, remove the ink cart to the right.
2. Plug in the printer, Press the POWER button, Do not release the POWER button, and then press the RESUME button twice in succession. Now release the POWER button, press the RESUME button 4 times.
3,The beeper may sound once, Then With the printer unplugged, after that reset the printer electronics ,open the printer and this process is finished.
May 31, 2008 | Canon MX700 Office All-In-One InkJet...
Error code 6502
1-- With the printer unplugged, remove the ink cart to the right ,
2--Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3--The beeper may sound once ,Then Unplug the printer ,then power back up and reset the printer electronics ,open the printer and this process is finished. I believe this should take care of your issue, it's basically a cold reset for the printer, Give it a shot...
May 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
249 people viewed this question
old marine
old marine
