Question about Ricoh Aficio 1013F Copier
Pls. my Konica 1212
Pls help me my Konica 1212 copier is showing F35 and onthing is working on it, pls is there anything i can do to resolve this problem without calling someone pls..!
  • 145 Answers
Power supply went bad!
try this Reseat CN15 on CB than check the oporation of L1 L2
47 mode 00
hope that help
Posted on Oct 12, 2008
How do we reset j12 on konica 1212
power off then depress 2 and 5 and power on
Mar 28, 2016 | Konica Minolta Office Equipment & Supplies
On Konica 1212 what does J11 mean and F54?
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Dec 05, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
I have a konica photocopier modeal 1212, it doesn't work at all and shows P27. what does this means. thanks
The P 27 code is the change the toner.Please change the toner close the doors if the machine it turn OFF press and hold the 4&5 keys and turn ON the copier.Change using the ZOOM key 47,50,51,52 and press the START button the perform the toner setting.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Error F35 ON KONICA COPIER
Yes you can, but need to know what model you have. different service mode for different models?
Oct 07, 2008 | Office Equipment & Supplies
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Aug 01, 2008 | Ricoh 6513 Copier
Error code f-35-8
On most Konica copiers, an F35 error indicates:
1. low temperature of the fuser; and/or
2. open lamp; or
3. open thermo wire fuse; or
4. open thermistor; or
5. or anything heat related at start or warm up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Office Equipment & Supplies
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Mar 19, 2008 | Office Equipment & Supplies
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
170 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
