Fax how to canact
    Sergeant:
  • 306 Answers
Fax works easiest via a dial-up modem though there are programs that allow broadband facsimile transmission. Use more words and you get better answers. ~Steve
Posted on Oct 21, 2008
Local area canacted but not resive bite
What is the exact error message?
Do you see any error codes?
Mar 01, 2013 | ASUS Computers & Internet
My phone is Canact to pc is not Charging from pc plz solve my problam so please thanks . M.parvaiz khan
maybe the problem is your usb cable.try to use another usb cable for your cp to figure out the isue
Sep 12, 2011 | Computers & Internet
Not canact to computer
I suggets reinstalla the software in the pc; check in this link to donwload the right program and drivers: aiptek.com/drivers/pcm13
Hope this helps.
Dec 14, 2010 | Aiptek Mini PenCam Digital Camera
My jvc tv doesnt make any sound
this problum solution is 3 type .
[1] Repaer tv sound section replace sound ic and canacting spaer
[2] Use extra amplifer or home theater system{AUX mode} canact with tv. A/Voutput pin .
[3] if you are use setup box or chenal convater then canact A/v Out{ L -R ] to AUX input . home theater or extra Amplifer system
selact any one option and enjoye....
Oct 30, 2009 | Televison & Video
The tv comes on but the picture tube has gone bad. at first if i warmed the tv up it eventually came on. the all at once the tube went out completely. i need to find a repair place where i can find an buy...
check tv screen on three colour RED /BLUE /GREEN is prasant but light or contrace is low .
if yes
then
first option is video output voltage 180v dc.canacting capaciter Replace with 10uf/250v dc
second option filament voltage 4.5v ac to up 6.5 v ac
and see pictur qulaty is improw .
theerd option is pictur tube charging 3 cathod
after change tube
see tube find this addrees
Setup Guides, Technical Support, and Instructional Videos :::::
Global Sourcing Solutions & Commerce LLC, DBA
Sadoun Satellite Sales
2747 Westbelt Dr,
Columbus, OHIO 43228, USA
(Map)
Office & Phone Service Hours:
Mon - Fri:
Sat:
Sun:
9AM - 6PM EST
9AM - 4PM EST
Closed
1-888-519-9595
Local: 1-614-529-9560
Fax: 1-614-529-6770
Oct 29, 2009 | RCA F36650 36" TV
Picture on tv keeps going out and coming on
If the previous posts didn't fix youru problem, and I doubt they did, then you most likely have a weak CRT and the video is being muted. you can sometimes tell if that's the problem by turning up the screen voltage slightly to see if the picture comes back on. If it does, then the CRT is weak. This is a very common issue with Sony CRT TVs, and can sometimes be rejuvenated by a good shop for fairly cheap.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
Sony trinitron only in blacka nd white. how do I return it to colour?
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
Oct 05, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Tv wont turn on (wont stay turned on)
pls. check power coad is likage or luse canaction in plugh
if ok then problum is inside of tv so pls. cheked in pcb.....
1st : SMPS output voltage and 5v /12v/ 24v /135v dc filter capaciter cheked and replace 470/16v /1000/35v / 220/450v if any capaciter likage or sort * first cheked dyode.
2nd : EHT output line capasiter or dyode checked 4.7/250v /100/160v
and line coil or 1ohm register cheked
3rd : DT (driver transfermor ) and with cancting spear dry.
note: pls descanect tv with DVR and cheked tv set is turn on atlist 10min. minimum with any ather product (DVD , GAME BOX ,CABEL CANACTION) if is ok. then problum in DVB setup box .
Oct 04, 2009 | Samsung LN40A550 LCD TV
Unit conitues to search for base and shows "System Busy" when attempting to dial out. Have registered phone .Other units work
its neem that the canacters on the phon are dirty try to set it on the base and see if it will charg
Aug 05, 2009 | Lands Phones
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
