Question about GE Energy Star WCVH6260F Front Load Washer
Smelly washer i had no idea there was a trap in there...thanks so much for your info. if you r curious...i found a pocket, about $2.00 in change, a coat hanger piece, a pen, and alot of lint...wow. thanks again frank rukycop@yahoo.com
  • 725 Answers
There is a washer cleaner from whirlpool Affresh works good
Posted on Nov 17, 2008
Moldy smell in maytag washer
Check the drain. It SHOULD stand about as high as the washer, behind it, and it SHOULD have a trap below the floor (basement?).
If the drain's good and the trap is fine, then the pump could be borderline - it it doesn't pump all the water out, some water remaining in the washer may become stagnant and smell funky.
Jul 25, 2014 | Washing Machines
Tip
Smelly washers
OK there are a lot of people with the smelly front load washer . the smell is caused buy a build up of detergent it is recommend that you use 2 tbs of detergent and 1 if you have a water softener. also leaving the door open after a washing is good to help it air out . to often people blame the door gasket because they get spots on them well the rubber used is a antimicrobial rubber so it cannot mold . the smell is actually soap build up trapped inside the washer if you run your washer with nothing in it and see soap suds your using to much detergent. there is hope though cutting back on detergent and using a product called Lemeshine mc3 will eliminate the odor issue.
on Jun 03, 2010 | Washing Machines
Tip
Yuck! I won't gross you out with what all I found in the trap, except that I...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Sep 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Odor inside the machine
Odor in the machine or clothes is a common problem with front loading machines that use a small amount of water. Fortunately there is a solution. There is a couple of cleaning products out there that work great to help this.
- Affresh
- Smelly Washer
They can be found where you buy detergent. I have found the Affresh to work the best but have heard great things about Smelly Washer too.
Here is a link to a page I put out that tells a bit more. Let me know if this was helpful to you.
Thanks
Washer Odors
May 22, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I have a Whirlpool Duet front loading washer with a smelly trap.
It is normal to have water in the drain lines and drain trap even when the unit is not in use. There's usually about a gallon of residual water in the lower portion of the wash tub, drain line and pump. If you are experiencing sour odors from the washer, the following link can give you some pointers on things to try to help keep the smell from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Read through the link provided and let me know if you still have problems. I personally own a front loader and have followed this regiment for 9 years now with no odor or mildew problems. I hope this helps you as well.
Jan 28, 2010 | Whirlpool Washing Machines
Takes hours to wash a load of towels
Just found out that there is a drain trap that can get clogged and needs regular maintenance. Take out the bottom panel by removing 3 phillips screws (7mm nut driver optional). Unscrew the trap (water will probably drain out so be prepared). Clean out debris. You may also have to remove the hose connected into the trap in extreme clogged cases. Just use pliers to release the hose clamp.
Replace the trap plug, hose (if necessary) and the bottom panel.
Good luck!!!
Bryan
Aug 24, 2008 | GE Energy Star WCVH6260F Front Load Washer
Bosch WFMC 3200 possible leak?
It is normal that there is water in the trap, which is your filter. You clean this not after every wash, it depends on your usage. I have my machine trap looked into once in 2 months; i use it once a week. Of course i clear all pockets of clothes before i put them in machine.
Jun 05, 2008 | Bosch WFMC 3200 Front Load Washer
Coin trap
Bosch, the maufacturer @ 1-800-944-2904 says there is "no" coin trap so whatever is lost in the washer has been flushed down the drain , lesson learned : check your pockets and collars before you wash,everytime.
Jun 14, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
GE Energy Star WCVH6260F Front Load Washer Logo
50 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
