Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Er FF ON THE BORD
WHEN PLUG IN WORK FOR A FEW MINUTES
AND COMES BACK THIS Er FF PLEASE HELP WHAT I SOPPOSE TO DO TO GO MORMAL AGAIN
  • Lee2fixit May 11, 2010
    When you open the door, is the fan inside running? Not the one under the fridge, but the one inside.
  • 218 Answers
FF usually means the freezer fan is not working. If the fridge is cooling poorly, check to see if the fan inside is running while the compressor is running. If not, and if there's no ice jamming it, then you need a new evaporator fan. If the fridge is cooling normally and the only symptom is the error code, then it could be a problem in the electronic control.
Posted on Oct 12, 2008
    Master:
  • 363 Answers
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
Posted on Dec 24, 2016
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Error code ER FF
code for defective freezer fan motor. ER FF
Sep 21, 2009 | LG LFX25960ST Stainless Steel French Door...
My kenmore Elite 795.77569600 fridge has er ff code
I pulled plug out of the wall socket waited a minute re-plugged unit in and so far error hasn't come back.
Sep 01, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Er ff what's that?
FF(Freezer Fan) this is the fan that circulates cold air thru the freezer as well as the refrigerator. If this is the first time the er has appeared, you need to unplug the unit for about 10 minutes, plug the unit back in. This should reboot the unit and erase the er.
Jul 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
ER FF in display ,DISPLAY IS LOCKED, LOUD NOISE
er ff indicates that the computer on your refrig is not sensing freezer fan operation. a guess as to your problem is that the fan is hitting on ice (the noise your hearing) and teh fan is not able to reach operation speed causing the error code. the fix would be to remove the ice from the fan area either maually or by unplugging the unit and letting it defrost for several hours. also to reset the computer you will neeed to unplug it for a few minutes then plugging it back up. hope that helps thanks Peyton
Feb 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
LG refrigerator isn't cold but bottom freezer is freezing the food
ff is fresh food may be the ff thermisor but i would first check the freezer back wall is it frosted up can you hear the fan in the freezer blowing the air up to the ff section
Jan 05, 2008 | LG LFX25960ST Stainless Steel French Door...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
512 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
