Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer won't wash
I have a frigidaire, front load washer that will fill up, set for a long time (not wash) then drain and spin. The washer fills with water and makes small clicking sounds like it is going through the cycles but does not wash or spin.When I rotate the drum the motor shaft moves but the motor shaft does not move throughout the washing/spinning cycle.It does pumpout at the proper cycle.I have cleaned the coins and things from the pump inlet.
  • ebrabham2006 Oct 11, 2008
    I do not know how to check the continuity but will try to find out.I assume you mean I can check but not replace the brushes in situ?
    You should also know that we feel the spin cycle has been slow for several months prior to the recent problem.Does this still sound like the brushes??
Checking brushes can normally be done in situ. you will need a simple multimeter to put across brushes to check continuity but disconnect wires to brushes before doing this. worn brushes would normally cause no motor rotation at all.
replacing brushes can sometimes be done in situ but often it is easier to get the motor out.
Posted on Oct 12, 2008
    President:
  • 1,462 Answers
Fault may well be motor brushes need replacing. check continuity across the brushes - you should be able to do this with motor in situ
Posted on Oct 11, 2008
I have a Frigidaire washer 2003 model no. gitr 1670 aso front loader that will not wash or spin. Everything else works like fill with water and water drains.
Hi friend, thanks for your post!
I see that your Frigidaire washer is not washing or spinning but everything else is working properly. I would advise you to check over the drain hose, make sure it is not restricted or too far down the drain pipe. If that checks out it could be a possible problem with your motor or control panel. One of those components could need to be replaced and for proper replacement I would recommend assistance from a technician to have a proper diagnosis completed. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire GLTF1670A Front Load Washer
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Jan 11, 2012 | Frigidaire GLTF1240A Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire GLTF2940ES Front Load Washer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
