Pass side fog lamp blew. Replaced and still won't light. If turned on, driver side fog lights but I lose the pass side turn signal completely. Fog light switch off, all turns back on. This does not effect the main headlight. (Fogs are standard factory issue with switch a pull-out on left steering wheel column turn signal lever-- not a after market add-on) thanks
SOURCE: how to change H3 fog light bulb in 2000 jeep cherokee sport?
Open up the lamp there is a clip that holds the lamp in place, replace the old one with the new one.
Be carefull and do not hold the bulb on the new one. Hold the bulb with
a tissue. The nabody oils will make the lamp burn out prematurely.
SOURCE: The inside of the car fogs up and on very cold mornings ice forms
This can be caused by a heater core that is leaking inside the car, one way to determine if that's the problem, is if you can smell antifreeze. It is a 'sweet' smell, and is quite noticeable. If u don't notice this, I have to say this is a common problem w/ Hondas. I've had a civic, 2 accords (currently have a 92), and 2 Preludes, they are great cars, but they all suffer from fogged up windows in cold weather. One reason is that they are quite air tight, and the older models don't have the greatest defroster system (weak). Try and keep a window cracked open slightly, see if that helps.
SOURCE: Wiring front fog lights to a 2002 freelander ES.
Do not fit these lights yourself,you must take the vehicle to the dealer to have it done .Firstly as vehicle wasnt factory fitted you need the original homoglonation certificate from the manufacturer for the model with the foglights fitted,then you need a installation project drawn up by certifide auto engineer with the relevent technical qualifications (i have them) then they can only be fitted by a garage with an added value tax certificate,then vehicle must be presented to the local vehicle inspection depot to be mechanically inspected all over weither its due or not,the relevant paperwork plus the fee presented ,then a new vehicle registratrion document issued showing the changes.Failure to to this will cause the vehicle to fail its inspection when next presented as paperwork isnt correct ,the lights are ilrevelent as to weither they work or not,but if fitted from new they must work.Also if stopped by the guardis civil and paperwork checked,and they notice then you risk having the vehice impounded their and then on the spot ,big fine and the cost of the removal truck.
SOURCE: fog lights don't work
In my 99 Cherokee it was the switch itself. Bought one online for about 20 bucks and it took about 5 minutes to replace.
SOURCE: 2001 jeep wrangler sport ,fog lights on, switch off
I have a simular problem. Only mine does not some on. I tried to replace the turn signal switch assembly with a used one. The replacement work ok on the fog lights but the rest was bad. As near as I can figure it, the switch assemble is not well made and had many ways to go bad. Either replace the whole assemble or wire in a bipass switch. I am going to go with a bipass switch. I don't trust the new jeep products.
