Question about Hitachi 61SDX01B 61" Rear Projection Television
Hitachi Projection TV
The projection TV is 8 years olds. Recently, it takes a long time to display a picture when turned on.(approx 1 min.). The picture is very dim, and appears to be slightly blurry. We have tried Magic Focus, but it doesn't seem to improve it.
  • 2 more comments
  • ccpmac Oct 17, 2008
    I see no problems with any resistors. I now have no picture at all.
    If this is the best advice that can be given I would like my money back.
    It went from dim to gone in 4days model 61SDX01B
    should all 3 bulbs go bad at the same time
    Problem Solver:
  • 5 Answers
2.5 ohm resister at R43 center board is bad , it is a 5 watt resister , my tv did the same thing , $.69 part
Posted on Jan 19, 2009
  • johnhenry201 Jan 19, 2009
    2 watt not 5 watt
    Genius:
  • 1,139 Answers
Hello ccpmac
Ok your symptoms were the screen take a long time to display a picture and when it does it is dim. Now this can be caused by a few things first lets look at the most likely. That would be the High Voltage supply to the CRTs (picture tubes) since the High Voltage supply to these is common I would like to explain what might be wrong. If the High Voltage off of the IHVT (also callaed the Flyback Transformer) is low this will cause a lost of what is called raster which is the light of the CRTs without video signal. This would mean that your IHVT is bad or the trippler is bad the trippler multiplies the voltage by 3 and sends it to each of the CRTs. Now if the IHVT or the trippler is bad they will have to be replaced. Here is how to identify them the IHVT is usually a large semicircular component with one thich red wire coming from it and two smaller wires also coming from it the two smaller wires will go to what looks like to knob controls (focus and screen, these may or may not be present), now the tripple is attached to the IHVT by the one red wire and the tripple has three red wires (in addition to the one red one connected to the IHVT) coming from it to the High Voltage anodes of the three CRTs. To measure this voltage you will need a High Voltage probe, clip the ground led to the ground of the TV and insert the metal tip under the rubber protectors of the CRT and measure the voltage from the meter, it should be about 20K-40K for each of the CRT anodes.
If the measurement is bad you will have to replace the IHVT and the trippler (find the part numbers and get them from your local Electronics supply wholesale store).
Now if the measurement is good, the only other problem could be the filament voltage of the CRTs this voltage is about 6.3 volts to 12 volts and can be measured with a multimeter set to DC volts. Find the filament pins of the Tvs schematic and check the voltage. If it is bad then you may have to replace the filament voltage transformer (which in some cases is a winding off of the IHVT) or you can use a CRT filament enhancer (take my advice don't use these things).
After all of this if the readings are good then the only thing left is to replace the CRTs them selves, but before you do that you can use a CRT rejuvenator to try to recondition the cathodes, and remove possible grid to cathode shorts of the CRTs. You will need a CRT rejuvenator to perform this task.
Now if you understand evey thing I have told you then you should have no problem because I have assumed that you have a background in electronics, however if you do not have a background in electronics, I would suggest that you get a qualified TV repair person to perform the tasks that I have mentioned here.
I wish you well and hope that this helps you.
Thank you,
Shuttle83
Posted on Oct 17, 2008
    Genius:
  • 1,124 Answers
The projection tv use a replaceable bulb. The life on the bulb varies but generally expect around 6 to 8000 hours. However some will last substantially less. Due the age of your tv probably you need to replace your bulb. Your tv need to be serviced.
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    I suggest to buy a new one instead of try to fix it due the cost
    Scholar:
  • 74 Answers
Has the image gotten dimmer over a period of time or is this a sudden development? Also, could you list the model number of is it the model in the heading? If posts didn't wind up in the wrong thread I wouldn't question the model.
    Master:
  • 538 Answers
Well..I would say that this one has done a majorly long run..and with the cost of replacement components..well..it may be time to retire this unit
    Brigadier General:
  • 3,614 Answers
It seems that yo got the problem on the video output module.. try to look and check for any defective resistor on this area..
BTW.. when the picture come out did the color was normally detailed..?
Posted on Oct 12, 2008
  • micromaster
    micromaster Oct 17, 2008
    check for any bad soldered on the board.. this can be another cause.
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Hitachi 50V720 Rear Projection TV
Good Day, douganddawnc;
What ever is popping is locking up the CPU circuit. Call a Factory Authorized Service Center Have figure out what is popping, get an estimate first. Good Luck, big IRISH.
Aug 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
HITACHI BIGSCREEN TV MDL 57TWX20B APPROX 4-5 YEARS OLD...TV SHUT DOWN WHILE WATCHING AND WON'T POWER BACK UP
This can be one of two problems. 1: convergence output ic's need to be replaced. 2: The problem is in the power supply, most likely a power diode.
Both problems you will need to take it two a repair shop.
Mar 15, 2008 | Hitachi 57TWX20B 57" Rear Projection...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 43FWX20B picture problem
yea take the set to a tech reprogram.or take out the plug and plug it in after 30 min.if the problem does not go.do as i say.good luck.
Apr 04, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
