Question about Maytag Dryers
Maytag Gas Dryer - Flame starts and then turns off 5 seconds into cycle
I have a Maytag gas dyrer that the flame is not staying on very long once you start a cycle. You can see the igniture turn on, then you can hear the gas valve switch on, the flame ignites and then within about 5 seconds the flame turns off and will not reignite until you turn the dryer off and then back on again. I thought at first it was a temp switch on the top of the burner housing because when I put my meter on it at voltage coming out of the contact to the gas valve. But about 5 seconds after the flame turns on the temp switch turns off and the gas valve drops out and the flame dies. Any ideas? I'm very handy and we have a very good appliance parts store in town. I just need an idea what part to check next.
  • 943 Answers
HI thanks for your question. the coils on the gas valve are faulty . common problem with gas dryers , replace the coils thanks the appliance doc. please rate my answer. thanks
Posted on Oct 11, 2008
  • Russ Klimczuk
    Russ Klimczuk Mar 30, 2014
    Hi John, I have the same exact problem and did replace the coils, but the problem continues unchanged. I did not meter igniter due to strong flame nor heat thermostat, since continuity at room temp. Also vacuumed and washed lint trap. Any additional thoughts. Thank you, Russ (ta197764@gmail.com)
Maytag gas dryer LDG7500AAL flame won't stay on longer than about 5 seconds.
The resistance is too weak in the hot surface ignitor to keep the gas valve open and requires replacement.
Dec 22, 2013 | Dryers
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
Jul 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
After first Ignition cycle igniter stays on too briefly to open gas valve gas.
Valid Most likely the problem with your dryer is the coils for the gas valve. Remove the access door (on the bottom right side on the front panel) and you can see the gas valve with three coils on top of it. They are coming as a kit with complete instruction. The part number for this kit is AP2669614.You can buy it here http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542517043&type=10&subid=
Jan 16, 2007 | Maytag MDE2706 Electric Dryer
Dryers Logo
308 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
