Question about Nokia N73 Cellular Phone
Forgot n73 phone lock
I have forgotten my n73 phone lock it is off now but i wish to activate it is there any procedure to unlock or reset it..............
  • Nokia Master
  • 1,800 Answers
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager
check the folder C:\System\mmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 6300.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
by Mr.Ginko
plz do rate this post
Posted on Oct 11, 2008
Forget the phone lock code
To unlock handset you have to give your mobile EMEI number which is backside of the phone,just remove it,you got the IMEI number,then you have to give your network service provider.
Feb 14, 2009 | Nokia N73 Cellular Phone
buddy use the following software to know ur phone unlock code..
Download unrar and run LockCode.exe file.. all instructions will be there for u as well..
LINK: [Only Registered and Activated Users Can See Links. Click Here To Register...]
Nov 22, 2008 | Sony Ericsson Walkman W810i Cellular Phone
download nss software on yur pu and see sth security option in it. u can see the code in it.
May 22, 2008 | Nokia N73 Cellular Phone
If you need the SIM Pin number to switch the phone on, then you have to enter any Pin number 4/5 times, then the phone will request a PUK number. This number was on the plastic card that your SIM card was attached to. If you don't have it, only your Network Service Provider can supply it to you.
If it's the Security code you need, to get into certain settings IE. erasing received calls, missed calls, timers etc... the Nokia default is 12345 if you didn't change it, but if you did change it and you've forgotten it, let me know, I'll tell you how to retrieve it.
Mar 06, 2008 | Nokia N73 Cellular Phone
Forgot my lock code for N73
you need to have a master reset code to reset all the settings. I do have an unlocker for this. if you want just give me the IMEI code and I could process it for you FREE.
Feb 26, 2008 | Nokia N73 Cellular Phone
you can give me your imei number i can tell you the lock code
for imei number press *#06#
Feb 12, 2008 | Nokia N70 Cellular Phone
hi there...
there is no way to get your password back...
just format your phone and this will remove the password option....but you will loost all the data stored on your phone....but data on MMC will be safe...
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 10, 2008 | Nokia 6630 Handheld
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
  1. Switch off the phone.
  2. Hold down the following three buttons: Green (call answer) button, * button, and '3' button
  3. While holding these buttons, press the power button and switch on the phone
  4. When the message 'Formatting' appears on the screen, release all of the buttons
Note that you shouldn't switch the phone off or remove the battery when performing either of these operations, and it's advised that the handset has a reasonable amount of battery charge before performing a format/reset. As data will be lost, you are advised to perform a backup first.
If this method doesn't work you probably will need to go to a Nokia Service Centre and have your phone flashed!
Feb 09, 2008 | Nokia N80 Cellular Phone
i have a problem i forgot the code of my 6630 nokia phone..what can i do?how to unlock and i dnt know what is the IMEe no...pls help me
Feb 01, 2008 | Lands Phones
Nokia N73 Cellular Phone Logo
91 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
