Lost internet connection after trying to pair asus ee pad with hp printer. can get internet on sony vaio, but tablet says no internet connwction.
SOURCE: I forgot my pass phrase...what now?
There is a button on the router itself that allows you to reset your netgear to the factory specifications. While this will allow you to get admin access back if you've forgotten your passcode, it will wipe out any network settings you've made.
SOURCE: I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Testimonial: "I received great help! I got speedy replies and great information at a level I could always understand and proceed to work with. Great first experienc"
SOURCE: i cant connect my netgear router to my sony vaio the
Follow the steps below to reset and reconfigure your router:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
