Question about Lexmark X5150 All-In-One InkJet Printer
Hook it up
I need to connect to my laptop but can't remember how it was connected before. I am looking for some type of diagram but so far nada.
  • Russ Andrews
    Russ Andrews May 11, 2010
    It will either be a printer port or a usb port. What kind of printer and pc?
    Problem Solver:
  • 7 Answers
1. Install the Drivers for your printer.
2. The driver installer will ask you to plug your usb cable or tell you when its ok to, so, just plug the usb cable into any spare USB port.
3. The drivers will detect the printer and complete the install.
4. If you have the all-in-one center you can install that too.
regards lee
Posted on Oct 16, 2008
2002 Ford Escape 3.0 engine How does the vacum hoses go?
There is no order to connect them. They will only stretch so far and go on certain ports on the plenum.
Jan 18, 2015 | 2002 Ford Escape
Acer Aspire 5630 hook up to television
Your Acer laptop has a 15-pin VGA port on the rear. It may also have a S-Video and/or a DVI-D port. Any of these can be used to connect to a television monitor. None of these connections, however, supports the sound portion of the signal. You will therefore require two cables, one for the video, and one for the sound. The sound will be a regular 1/8" stereo jack on the PC side. You will need to look at the TV to see what types of connections it accepts. There may be HDMI, DVI-D, S-Video, or RCA connections. Select a cable which matches the connections for each end for both the audio and video.
Dec 11, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Can't hook to sonybravia using VGA to HDMI (pc to TV)
Do you have some type of converter that is changing the VGA connection from the laptop to a HDMI connection on the other end that goes into the TV? Otherwise, you'll need one.
If you have them both connected then on the TV you will need to select HDMI as the input.
Apr 02, 2012 | Computers & Internet
I can not remember my password for my DIR-628 Wireless Router what can I do
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
kindly rate this post
Jan 02, 2012 | D-Link DIR-628 Wireless Router
Need to reset network passcode
Dec 28, 2011 | Belkin F5D7234-4 Router
I have a dynex TV I am trying to connect to my laptop via HDMI. The TV works fine as far as displaying cable but when I try to hook it up to my laptop the screen displays for one second then flashes to...
Make sure that you set your laptop to external display by using the proper F key, located on top of the keyboard. It looks as though there are two computer monitors on it. My Gateway is F4 for example. Press the function key and the proper F key simultaneously. There are a few choices, so you may have to push it more than once. I hope this helps and good luck!
Please remember to vote 937f12f.jpg Thanks.
Oct 31, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
How do i connect my acer aspire 5810T to my tv, thanks
I am assuming that you want to display your laptop on your TV. Since you did not post what TV you have, I am listing multiple ways to connect your laptop to your TV. Just pick the right type connection that works for both your laptop and TV, connect OUT of laptop to an INPUT on your TV. Set your TV to that input (mode) and if you see nothing on the TV, look at your laptop keyboard at the F keys (function keys) for the one with a double display image on it, pree the function button and the F key to set the laptop to external display.
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
If by chance you are attempting to hook up the TV to the laptop to capture video from the TV, you need to hook up your wire to the OUTPUT of the TV and you will need a capture card or hardware and software to do this. I hope this helps and good luck. Please vote appropriately and leave a comment.
Oct 29, 2009 | Acer Aspire AS5530-5824 Laptop
I have an acer aspire 5100 laptop i need to hook up to my tv for a presentation tomorrow. there is no s-video output on it,. how do I hook it up to my tv?
If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
Oct 09, 2009 | Acer Aspire 5100 Notebook
Homelite XL2 Auto - Proper Oil Line Hookup
Go to m-and-d.com then parts diagram, then illustrated parts online, then parts look up then select oem type select homelite then type in the model no. The parts diagram should show correct hook up.
Apr 06, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Printer not able to hook up to new Dell
your printer the g85 on the backyou will see below yhr bar codes where the power cord is four connections. looking at it from the back facing you on the far right is the power cord next to the power cord is the cord from the top lid second from the left i dont use this but i think it is the serial connection and far left connection is the usb cable the usb is the best on to use the two phone lines on what i call the leg or base far left remmber they need a special phone cord most cords only have two wires hooked up this on needs all four or it just want work right.hoop this helps
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
