Question about Pioneer Audio Players & Recorders
CD STOPPED PLAYING AT TRACK 3 AND NOW WILL NOT PLAY AT ALL. PD-65 HAS BEEN STORED (NOT USED) FOR SEVERAL YEARS APPRX 7. DOES IT NEED CLEANED
  • Pioneer Master
  • 19,396 Answers
First try ejecting the disk and unplugging the unit power cord for five minutes.
if that did not work, that probably means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
Ifthat does not work, you will need to take apart the unit, access thelens pickup, and clean the lens directly, using isopropyl alcohol and acotton sticks.
Posted on Oct 11, 2008
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
CD player clicks while playing some CD's
Sounds like it's worn out, best take into the shop for repair, should only cost $20 with parts.
Dec 25, 2017 | Pioneer PD-M426 6-Disc CD Changer
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
CD player not working
Chances are there is some dust on the lens of the player. You might need to go inside and clean it off with some Servisol Video 40 or other suitable lens cleaning stuff. The dust might have got disturbed when you put it into storage.
Jan 28, 2018 | Audio Players & Recorders
Put a cd in playey, plays for around 20 seconds stops playing then restarts playing and keeps doing the same
sounds like the laser tracks might need regreased to me, does it also skip when playing ?
Feb 07, 2010 | Teac PD-H300 CD Player
CD player acknowledge CD, starts to play, then stops
I belevie you have problem in laser assembly it might not worth to repair it
Cheers
Dec 10, 2008 | Audio Players & Recorders
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
Cd-player (recordable) stops at about track 4 on every CD I play
i,
Based on your post it would seem that the lens get stuck when moving along the slider at about the same position. You can try opening the unit and performing a manual clean and re-application of any thin lubricant. Additionally you can use a can of compressed air to blow accumulated dust and foreign debris inside the unit. The slider would be the small rod encircled in yellow dotted lines.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 28, 2008 | Audio Players & Recorders
Sony DAV-SC5 Home Theatre System problem playing CD-RW's
Hello, your home theatre system is from the year 2003. Maybe a cleaning the optical can solve the problem. There are cleaning CD kits on the market, but better option is if a pro does it (the cleaning) for you. If you need more assistance please advice. Arpi
Mar 22, 2007 | Sony DAV-SC5 System
35 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
