Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley starter motor install instructions
I need instructions on how to re assemble and mount my stater motor and soleniod on my evo softail
  • 8 more comments
  • soot_e
    soot_e Oct 11, 2008
    sorry i didnt make myself too clear on that one...i meant more to do with the electric side of things
  • soot_e
    soot_e Oct 12, 2008
    yeah you could say that...i took the starter and soleniod rite out the other day when taking off inner primary.trouble is i didnt tag n bag anything because it seemed to be pretty straight forward but now im putting it back together along with the wiring it aint firing up.instead with the run switch OFF im getting a click (one) from the relay when i hit start button,if i change a wire on the main c/breaker to the other post i get a click from the relay when the run switch is ON but still the starter isnt being engaged.the rest of the wiring seems to be fine..the lights and flashers work fine.
    i thought maybe if i got a link to pictorial or something along those lines i mite be able to get it sorted
  • soot_e
    soot_e Oct 14, 2008
    mitchy i thank you for your patience!ok heres whare im at:my starter motor was in pieces but since putting it back together im having this problem.the wiring config is as follows...the '+' term is on the solinoid pole, from the '+' term on my battery i have a wire to the the copper ploe of the c/breaker, from the '-' term the battery is first grounded then i have from the '-' term i have the rear loom
    the relay is like this: 86 is hooked to the silver ploe of the c/b
    87 is to the starter motor conection at the rear of it
    30 is to the silver pole of the c/b (aswell as the volt regulater wires)
    85 is a mystery!!iv tried many things inc...grounding it to the bike (bike
    doesnt crank but seems to be the best place?? if its on the copper pole it only
    clicks the relay if the ignition is off aswell as the run/off switch being off too.of on the silver pole the
    ignition can be on but the off/run switch must still be off.
    the wires to the coil come from the ignition (dash)
    if anyone at all can see what i am doing wrong PLEASE HELP!!!!!! i should mention that this system is not a harley loom but a custom loom bought from ebay (BIG MISTAKE!!!) with bits added on to as time has gone.this bike was working fine prior to me pulling the starter out while changing my inner primary recently
  • soot_e
    soot_e Oct 15, 2008
    indeed it does
  • soot_e
    soot_e Oct 15, 2008
    hey just something else to throw in the mix...2nite i pulled out the starte and bench tested it...if i connected the + term from the battery to the starter and the - term to the solenoid plug it should of wound up shouldnt it?
  • soot_e
    soot_e Oct 15, 2008
    YES PLEASE!! that would be great!! depending on your diagrams,im thinking about ripping this dodgey one out and starting from scratch.did you see the question i posted about benchin my starter?
  • soot_e
    soot_e Oct 16, 2008
    Mitchy you have gone above and beyond man!!cheers for that.i bit the bullet and went and bought a new starter today so i will fit it and using your diagrams as a guide will fix some of the wiring then that should do it....just wanna get on the blardy thang n ride it!!!
  • Mabel Margaret
    Mabel Margaret Jan 08, 2014
    Thank you for posting information on harley starter installation process!
  • Mabel Margaret
    Mabel Margaret Jan 29, 2015
    Good instructions on starter motor installation.harley starters
  • Orrick Owen
    Orrick Owen Dec 29, 2017
    Wonderful Post Keep updating.http://www.spraggusa.com/
  • 216 Answers
Its not a complcated procedure. You'll need to open your primary. You install the jackshaft into the starter after its mounted. Make sure you put plenty of ani seize into the bushing on the outer primary and watch out not to over torue the jackshaft bolt - the spec is 5 lbs.
heres a couple of links that will give you more info. One is for a spyke starter install, but all starters install the same. The other is for a belt drive install which talks some about the starter
http://www.wwag.com/downloads/HowToUse/Spyke_en.pdf.
http://www.bikernet.com/bdl/PageViewer.asp?PageID=375
Posted on Oct 11, 2008
Testimonial: "great help with a very good understanding of the subject"
  • 6 more comments
  • Mel Jacobson
    Mel Jacobson Oct 12, 2008
    Is your starter and solenoid in pieces ? Is that it ?
  • Mel Jacobson
    Mel Jacobson Oct 13, 2008
    Well, with the run switch off, there should be no click when u hit the start , so change to the other post .... Check your battery cables for a good connection and check your battery with a volt meter for a full charge. This link should go thru the process for you... its four pages with diagrams
    http://www.bikernet.com/bdl/PageViewer.a...
  • Mel Jacobson
    Mel Jacobson Oct 14, 2008
    On a stock evo softail all u have is the positive battery lead and solenoid wire. If thats connected and all u get is a click your battery may have run down or not be getting a good ground
  • Mel Jacobson
    Mel Jacobson Oct 15, 2008
    Ya know that part where I said it wasnt complicated ? well - forget that. Doesnt sound like u have a wiring diagram, so - heres a few things to try. (may or may not apply to your harness, this is sorta general stuff) There should be a wire (heavier guage, yellow?) from relay to solenoid. A lead from the relay to chassis ground (black). also on the relay - a copper post ( 30 amp breaker?) is wired to the + bat term and the silver post is wired into the loom. Does this make sense to u ?
    Step 2 in a minute
  • Mel Jacobson
    OK - just rechecked a few things, but it doesnt sound like u unhooked any coil connections - so i wont go into it. I can hook u up with some wiring diagrams if you need em
  • Mel Jacobson
    Bench test should have extended the starter shaft - let me get u a flow chart for that (hope I can find it)
  • Mel Jacobson
    http://www.chopperweb.net/forum/showthre...
    Several wiring diagrams
    hopefully u can access this - u may have to join the site first (its free) ..... which is a very good site for you anyway
  • Mel Jacobson
    Mel Jacobson Oct 16, 2008
    My pleasure bud .........
    Keep the rubber side down.....
    m
    Top Expert:
  • Harley Davidson Master
  • 14,162 Answers
Posted on Jan 30, 2016
Great link,cheers.still leaves the question of the starter and how its wired...is it just the batt terminal lead on the top pole and the solenoid on the bottom?nothing from the relay or anywhere else?
Posted on Oct 13, 2008
SOURCE:
1992 Harley Davidson FLSTC Heritage Softail Classic high torque starter
Hi, Laurel for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected] Good luck and have a wonderful day.
1992 Harley Davidson FLSTC Heritage Softail Classic high torque starter...
84 to 99 Harley Softail Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm free owners manual
Instant Repair Help over the Phone to speak to me personally $4
Aug 29, 2018 | Harley Davidson FLSTC Heritage Softail...
Remove stater from heritage softail
Hi Anonymous, here is the short version. Disconnect battery negative cable, drain and remove primary cover, remove starter jackshaft bolt while holding pinion gear, chrome starter end cap, all cables and wires, starter mounting bolts, remove starter. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 28, 2014 | Harley Davidson FLSTC Heritage Softail...
Starter hanging up
Hi Anonymous, you have either low battery voltage or your stater solenoid and or starter are faulty. Good luck
Oct 09, 2013 | 2000 Harley Davidson FLSTC Heritage...
1996 softail starter turns but will not engage
Hi Anonymous, you need a new starter drive, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Heritage Classic with Evo motor starting issues
2005 Harley Dyna FXDX starter replacement
Apr 07, 2012 | Harley Davidson FLSTC - FLSTCI Heritage...
How do i replace primary seals on 2000 harley softail transmission with 80in. evo motor
Hi Michael, it's too bad you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
Sep 30, 2011 | 2000 Harley Davidson FXST Softail Standard
Picked up vibration an its not coming from motor mounts feels like in the balancing part but i am not up to par on twin cam motors an not sure where this takes place
According to what this webpage is showing, you are talking about a 2000 FLSTC Softail. If this is correct, your bike has the TC88B motor in it. The "B" motor is a counterbalanced engine put in the Softail only.
It has two counterbalance weights in the engine, one at the front of the crankcase just below and in front of the front cylinder and one back where the transmission bolts to the engine. They are driven by a small single row chain and must be timed with the crankshaft. Sounds like the balancers have gotten out of time or quit altogether. I don't have much experience on the Twin Cam engines. I mostly work on the old Harleys like Panheads, Shovelheads, and Evos. But I do know the TC88B engine is a counterbalanced engine. Good Luck.
Dec 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
I need a free wirindiagramg for an 87 heritage
one jump the starter like u would a chevy at the solinoid at the top of the starter if this works jreplace the stater button at the bars and check the starter relay behind the cover at the oil tank also this particular year eats stater clutches and jackshafts the wiring is the same on this bike thru 94
Aug 31, 2009 | 2000 Harley Davidson FLSTC Heritage...
Have an 80 evo motor only running on one cylinder.
seems like ignition line short, like a plug cable or plug itself
Aug 08, 2009 | 2000 Harley Davidson FXST Softail Standard
Softail 98 Starter issues...
it sounds as if your inner primary is not lined up they do have a tendency to wear slots in the holes where they mount to the tranny and motor
Jul 08, 2009 | 2000 Harley Davidson FXST Softail Standard
Lands Phones Logo
8,010 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
