Question about Apple iPhone Smartphone
Iphone unlocked problems
I have unlocked my 2G iphone and it worked for a couple of days. Running 2.1 firmware. Now the keypad for using the phone does not do anything. Everything else works fine. Any ideas? Thanks!
  • abuwadee378 Dec 14, 2008
    the same here but 3g here.
  • Anonymous Feb 21, 2009
    here too 8GB 1st Gen
I am having same problem as well. When I touch the "Phone" Icon it will get to Phone Numeric screen but non of the key is function. I am having IPhone 2G and Firmware 2.1. Please help to provide solution.
Regards
Ben
Posted on Nov 21, 2008
I just purchased an unlocked i phone 1st gen and it was working fine with my tmobile carrier but all of a sudden i synced it with i tunes and now it wont let me make calls
Posted on Oct 11, 2008
Forget my iphone password
In order to fix this, you will have to restore your iPhone to its original factory settings. Hopefully you have all of your e-mails/documents backed up somewhere! (all your apps and music should be safe in iTunes.
Plug your phone into the computer and when it tells you that its locked, put the phone into DFU mode by pressing and holing the center button as well as the sleep/wake button for ten seconds. It will then go dark for several minutes and then boot back up.
Oct 04, 2009 | Apple iPhone 3G
What are the steps to update my iphone
Here is simple guide for those Users who will be first time upgrading their iPhone 2.2 or 2.2.1 to firmware 3.0. The guide is applicable for Upgrading iPhone 2G/3G 2.2 or 2.2.1 to OS 3.0 and also for iPod Touch. Please note in order to upgrade iPhone to firmware 3.0 you must have installed iTunes 8.2.
How to Upgrade iPhone 3G 2.2/2.1 to 3.0 firmware 1. Connect your iPhone 3G to computer
2. Open iTunes 8.2
3. Select your iPhone under Devices in the Source List on the left.
4. In the iPhone Summary pane, click Check for Update.
5. Click Download and Install. Do not disconnect your iPhone until the update has finished
That’s it, Once update is finished your will have iPhone 3G running latest firmware 3.0.
Please rate this solution
RNJ VINODKUMAR
Oct 02, 2009 | Apple iPhone Smartphone
Iphone 2g stuck at slide to unlock screen
Seems like the digitizer(which sense the touches) is not working. Replace with a new one and you'll be good to go
Jun 18, 2017 | BoxWave Corporation Apple iPhone 2G...
Iphone showing no service
If it was bought unlocked for under $700 then it was unlocked illegally after updgrading to 3.0 it is locked again. If you upgrade to any of appples unpdates your phone will be locked each time and you will have to wait for an unlock solution to be released each time. Currently there is no way to unlock the 3g under 3.0 firmware only the 2g is unlockable to the 3.0...I know case i have one. Jailbreaking and unlocking are different.You have to downgrade your firmware to unlock it. Restore your phone via iTunes using one of your old backups, you should be fine.
Jun 26, 2009 | Apple iPhone 3G
Got unlocked iphone, tried to restore factory settings now its stuck on bitten pineapple...any help plz just got this phone?
Here u can follow the steps
Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
“C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
Feel free to ask me any question here should you run into any problem during the update process.
Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
Download Links:
Download iTunes 8.2
Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
/**/ Thanks
Thiru
Jun 20, 2009 | Apple iPhone Smartphone
IPhone 2G hangs at "slide to unlock" - restore not helping
2g solution
3g solution
if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
Feb 04, 2009 | Apple iPhone Smartphone
its not a hardware problem brothe as i am also facing same problem...actually it all happen with jailbreaked iphone...ad i'hv checked its deep root directory there an application called "lockdown" is the main cause of that...nd still there is no crack of that.....
two days back i unlocked my iphone 2g it was working properly before that i was facing the same issue as you are facing....but now again it went to the same problem....
i hav a temp solution of that...
use blackra1n u can find it from blackra1n.com
nd for few seconds slide to unlock will work
or u can use it by connecting it with ur itunes ...connect usb wire nd slide it again nd again...u can unlock it..bue its just temp
Feb 04, 2009 | Computers & Internet
Tmobile sim still doesnt work after being unlocked.
if you have a 3g you cannot upgrade to 3.0 firmware and unlock it.
2g solution
3g solution
Jan 02, 2009 | Apple iPhone Smartphone
IPhone dialing keypad problem, 2g , 2.2 firmware
I just found the answer on another website. Go onto installer or cydia and uninstall Mobile Enhancer. Restart your phone and it will work. Thank god!
Nov 28, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
171 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
