Micro system will not recognise cds
When a cd is placed into the micro system iit tries to read it but comes up with 'no disc'. the only solution in the instruction manual is that the disc is damaged or upside down neither is the case.
  • 19,396 Answers
When that happens, often that means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
If that does not work, you will need to take apart the unit, access the lens pickup, and clean the lens directly, using isopropyl alcohol and a cotton sticks.
Posted on Oct 11, 2008
Sony CMT- eh25 micro system not reading cds
clean lense carefully then try if again massage comes replace lense
May 17, 2012 | Sony Audio Players & Recorders
My AWA UC550AR Micro System does not recognise when a CD is loaded
The problem is in the laser pickup, overtime it becomes weak until it can no longer read the disc, the only option is the complete replacement of the laser pickup assembly, but it is far cheaper to replace the player.
May 14, 2012 | Audio Players & Recorders
My MATSHITA DVD-RAM UJ870QJ ATA will not recognise an audio cd
i tried this and it worked when nothing else would.
http://sites.google.com/site/matshdvdfix/
Feb 21, 2010 | Acer Computers & Internet
Cd system does not recognise the cds on playing deck.
The unit is a 3 disc changer usually when these kind of problems occur there are quite a number of possible solutions.
When i faced such a problem it was due to the current being low. Then it was 200 volts instead of 220 so check yours and determine if the current is adequate otherwise you can get a voltage regulator.
On the other hand this happens when the lens is dirty or the CD is not properly placed but the second option is usually an off case.
Generally to solve the problem take out the unit from the mains for about 20 mins.
If you have the technical know how you can open the unit and try to clean around the CD tray. This should be done with utmost care as damageable components are around the tray(this is not compulsory if you cant).
After about 20 mins pug the unit back
Next get a CD lens cleaner and run it in the system to clean the lens of the unit.
put in a single disc and attempt to play. At this point the unit should function fine.
Hope this solution has been helpful?
Oct 07, 2010 | Teac DC-D4800 Shelf System
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
FILE SYSTEM RAW in cd properties and cant access blank cds,dvds
A blank disc is RAW until something is burn to it the burning program will format it to cdfs.
Jul 30, 2009 | NEC ND-6750 DVD±RW Dual Layer Burner
Sony system not reading discs
if cleaning does not work, then you need to replace the laser, this not hard to due if you have some technical
Jul 18, 2009 | Sony Audio Players & Recorders
Stereo won't read discs.
Did you finalize when you finished your recording? also try playing your new cd on your auto or home system
adolph
Feb 13, 2008 | Audio Players & Recorders
Device Won't Recognise Blank CD-R Media or Certain Music CDs.
try and see if you can pull a directory using explorer,, sometimes if you record to the full 80 minutes capacity, the disc will return an error,,,even if you recorded it on that drive...also i know this may sound strange but on the drive tray itself take the mount where the laser is mounted and extend it out to the furthest travel point ,,,gently,,,do not force...load the disc, and see if it is now recognized,,,sometimes it is a timing issue, and this way the tray/laser recalibrates itself....
Jul 03, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
51 people viewed this question
 Grubhead
Grubhead
