Question about Gateway FPD2275W LCD Monitor
Black screen with high pitch squeel
As the subject line desribes, my monitor does not work. All I get is a high pitch squeel while the screen remains black. The blue LED power light also does not work.
Is it the power supply? Can I replace this>
    Champion:
  • 293 Answers
Hi...there,
YEah...sure! You need to replaced or repaired your backlight inverter....
Posted on Oct 13, 2008
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitch squeel monitor will not come on
Where is the "squeel" coming from (soooooeyy!) Is it from the case speaker or a bad fan, or a bad hard drive? You'll hafta open 'er up an listen...
May 12, 2012 | Acer Aspire SA20 PC Desktop
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
ACER Al1916W goes blank in 3 seconds. It shows ACER splash screen for a sec., the desk top for .5 sec, then goes black. There is a very high pitch squeel each time there is any display. Power switch turns...
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Acer AL1916W 19" LCD Monitor
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Lcd monitor failure
your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Nov 11, 2007 | HP Compaq FP5315 15" LCD Monitor
High pitched squeel
change the dial settings on the side (there's letters from A to G)
Feb 16, 2007 | GN Netcom GN 9120 Professional Headset
Gateway FPD2275W LCD Monitor Logo
135 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
