Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine
Jumping around during spin cycle
  • Anonymous Oct 18, 2008
    I have the same problem even with small loads. I have checked the level and the floor it sets on is solid,
  • 750 Answers
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Posted on Oct 11, 2008
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Durning the spin cycle, the washer is jumping all over the place
One or more of the suspension springs have failed. Here is a link to the spring.
Take a look at this video.
Oct 15, 2012 | Whirlpool ATW4475VQ Washer
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine drum out of balance when spinning. have balanced machine and it does not vibrate or jump around. worse when on slow spin, real knocking sound
mine is also making noise during the spin cycle. Just paid $95AUD for the repairman to tell me it needs news bearings and that will be a further $300!
Oct 10, 2009 | Electrolux Washing Machines
Whirlpool Washing Machine is going to explode(shakes and shimmies)
put your level on the machine Adjust the legs so when you push down on any corner there is no rocking - easy
Nov 07, 2007 | Whirlpool LSQ9600L Top Load Washer
Vibration
Is the machine level. The feet should be tightened and the nuts should be tightened against the cabinet. Tilt the machine back and check the shock absorbers. One of the shockies could have jumped out of the guides.
Oct 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
417 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
