Question about Whirlpool Washing Machines
Error code F70 on Whirlpool frontload washer WFW9600
We tried to use the delayed wash last night but when we went to it this morning we had error code F70. There is a small possibility that the door was not closed properly, but we forgot to check. We opened the door, closed it and restarted it on a nondelayed wash and it started just fine. The manual for the washer is not very descriptive with the error codes, it simply says to restart and if that doesn't work call the repair man (what is this a microsoft windows machine?).
  • ikarmanov Feb 15, 2009
    WFW9400 there was error code F70, I get it unpluged, when plug it back it is not working at all
  • 750 Answers
Welcome spammailmd
You said, you tried to use the delayed wash last night but when we went to it this morning we had error code F70. There is a small possibility that the door was not closed properly, but we forgot to check. We opened the door, closed it and restarted it on a non-delayed wash and it started just fine. The manual for the washer is not very descriptive with the error codes, it simply says to restart and if that doesn't work call the repair man (what is this a microsoft windows machine?).
Whirlpool codes:
“F” codes other than F20, F21 or F22
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains,
call for service.
Let me know that it works for you or if you have any questions.
Thank You.
Please remember to leave a rating
Huuum
Posted on Oct 11, 2008
I fixed mine for no cost in 3 minutes!
We have a Whirpool Duet front load washer as well. For the past month we would get the f70 or the f71 error code and the waswher woud not work. I refused to begin changing components as suggested on web searches until I could determine the exact cause. Whirpool is absolutely useless in helping to fix thier problems.
Each time it happened I instructed my family members to leave the machine alone. I wanted to be able to troubleshoot the machine exactly the way it was when the problem occured. After several times I found the problem.
The door is a two part door consisting of an outer trim and an inter trim. The screws that hold the two together work loose over time and cause the door to not close correctly and move during the washing process which disrupts the signal to the door sensor sending an error to the control unit.
I tightened all of the screws with a torx screw driver and the problem is gone.
Posted on Sep 30, 2011
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
F 70 error on my whirlpool duet washer
Hi, F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board which needs to be replaced.
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Went to start a load last night sound like it was going to run but after a min. the water had not started and then a f70 flash on the screen and now it just beeps when you push start no light just sound
Hi
Thanks for using FixYa. Error F70 is a communication error between the Central control unit (CCU) and the user interface. To start with you’ll need to check continuity of the user interface and then check the wire harness connecting the user interface & central control unit. If the drum is not moving then central control unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Regards.
Ginko.
Jun 06, 2010 | Kenmore 47081 Front Load Washer
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
1,100 people viewed this question
Dan Webster
Dan Webster
Sal De
