Question about Acer TravelMate 2300 Notebook
Laptop Screen My laptop screen is not working properly it only works when its completely opened (180 degrees) or at angles less than 10. otherwise it shows blank and wierd lines!!
  • nanfas Oct 11, 2008
    thnx. btw i want to upgrage my notebook's ram. its currently 256MB . i would like to know which company ram and which model ram should i buy?
  • 535 Answers
Thats mines ur screen cable has been brok from the inside of laptop if u have in warrenty then take it the compnay service center or if u have finished warranty pedior then go with professionl repairer of lapotop
Posted on Oct 11, 2008
  • sandip panchal
    sandip panchal Oct 13, 2008
    u have bye same model of your in your lapotop currently have u shoud to do this open your laptop remove the ram & take it to seller he will give u same model of ram
The touch screen stops working when I open the lid past an angle of around 70 degrees
If this is a new laptop barely months old please contact the place you bought it. You will have a warranty on it, you will be able to get it replaced under warranty. It would be pointless anyone trying to help you fix it as it may void your warranty
Mar 15, 2015 | Computers & Internet
My HP Pavillion G6 laptop screen goes black if not tilted in two certain positions
Sounds like the cable feeding the inverter is either faulty or has a bad connection. You will need to take the laptop to bits. See utube video.
http://www.youtube.com/watch?v=M7CEtfJtu_Y
Hope that helps.
Dec 29, 2013 | HP Pavilion Computers & Internet
My laptop (IBM X201) runs but the screen remains black
i think this could be the ribbon cable that connects the screen to the motherboard,it has either come loose with opening and closing the case,or cracked.open and try reseat it,if you are capable and confident
Mar 19, 2013 | IBM Computers & Internet
I have a synaps monitor model mt9bbk. The screan will go black and power led will flash.
Display Power management is being triggered because no input signal was detected. Verify that the video source is connected and on. (Computer, notebook, etc).
- Try another computer or laptop that you know is working properly.
- Do you see any change on the screen if the display cord is completely disconnected (often a "Test" or "Check Cable" message appears). - Inspect the signal cable from the monitor - worn? Any places where the cable was bent to an extremely small (acute) angle? (less than 75 degrees?) Try gently moving the cable around at either end and see if you get a partial signal on the screen (while connected to the computer). If you do, the signal cable is damaged, if possible replace it. try: www.monoprice.com
Apr 14, 2011 | Computers & Internet
When i open laptop screen beyond 70 degree angle screen blanks out i then have to close d completly then re open lid making sure ot to exceed 70 degree angle
I suspect a broken wire feeding the screen.
Either take it to a computer repair centre or remove the case and check it out for yourself as it may be a plug not making good contact.
Be careful if you do!
Jan 16, 2011 | Advent Computers & Internet
How to fix a black screen on my dell inspiron 6000 laptop, it loads up then turn back black, i close down the laptop top and open it up again it works for a sec. then turns back black, what shall i do?
There is a cable between the system board and the LCD. It may be loose or it may be bad. If you open the screen partially to a 45 degree angle, does it stay on? If it does, then it is the cable.
Here is the service manual for your laptop:
http://support.dell.com/support/edocs/systems/ins6000/en/index.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 11, 2010 | Computers & Internet
Loose Monitor on a HP Pavilion ZV6233nr Laptop
It seems that some screw that was loose is now totally out of socket. The latch assembly might be disbalanced due to that. To me it doesn't seem to be a broken latch.
Apr 04, 2010 | HP Pavilion zv6233NR Notebook
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
Laptop Screen
The cable from the LCD going into the system board is loose or bad. Here is the service manual for your laptop.:
http://www.nodevice.com/manual/newmans/acer/SG_TM2300_TM4000_TM4500pdf/get48658.html
You may have to copy and paste the link into your browser.
Thanks, Joe
Oct 11, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
