2 hi-voltage resistors r2709 r4704 burnup when turn on power switch
Resistor r4704 82k hooks to pin 4 of flyback @ to ground.r2709 27k hooks to pin 4 too. @feeds to ic u1001 pin 31 beam sense in .hope you can help me. thank you . ED
    Champion:
  • 252 Answers
The resistor you mention is from ABL? if so, then the plyback had a problem
Posted on Oct 11, 2008
Tip
Blower motor does not work?
Blower motor problems are a pretty common topic. This is a basic guide on how to diagnose the problem and will work for most vehicles.
The diagram is generic and loosely based on GM's setup and more specifically a Silverado. Most manufacturers have a similar setup and the only major differences would be a ground side control (instead of the switch supplying power to the resistor it would be grounding the power from the resistor if this is the case you test light would need to be connected to power to test the switch) and late model Chrysler minivans (they use a module that looks for a difference in a/c voltage from the switch)
If the blower works on high only than likely the resistor assembly is the culprit since power to the blower essentially bypasses all of the resistors and/or the resistor assembly entirely. The reason why none off the other speeds will work is that the resistor or the circuit for the speed four setting has burned out. The lower the setting the more resistance you need to drop the voltage to the blower. The first speed setting requires all four resistors to drop the voltage enough to turn the blower at its slowest speed. Speed 2 needs to turn the blower a little faster so it uses three resistors. Speed 3 uses two resistors and speed 4 uses one.
In some cases the fan will work on high and speed setting 4. The likely cause for this is the speed 3 resistor or circuit has burned out. Speed 4 still works because it doesn't use the lower speeds resistors to control the speed of the blower. If the speed 2 resistor burns out than speed 1 and 2 will not work but 3, 4 and high will continue to work. If the speed 1 resistor burns out than speeds 2, 3, 4, and high will continue to work.
This leads us to how do we know if its the resistor or the switch or the blower. If the blower works on high than we know the blower works. That leaves us with either the switch or the resistor assembly (there are many other possibilities) which can be easily tested with a test light (or a voltmeter if you choose) The first thing to do is locate the resistor assemble. They can be behind the glove box, under the dash close to the blower motor or under the hood, again usually close to the blower motor. It will typically have 5 to six wires going to it. We'll start by unplugging the connector, turning the key on and connecting your test light to ground.
1.Turn the switch to high and backprobe all the wires. Two of them should illuminate the test light. In the diagram below this would be wire E & F. If you don't have a diagram then hold the test light on one of the two wires and move the switch to another speed setting. the wire that continuously illuminates the test light regardless of the switch position will be the constant power for high blower speed and will not need to be rechecked in the following steps.
2. Turn the switch to the next lowest setting. Backprobe the remaining wires to see if one of them illuminates the test light. Repeat until you have checked all of the speed settings.
3. If the test light has illuminated a different wire for each setting then we can reasonably assume that the switch is functioning as intended and the source of the problem is the blower resistor.
If you find one or more settings (but not all the settings) on the switch that does not illuminate the test light on any wire than we can reasonably assume that the switch has failed.
There are a few other things that can cause blower motors not to work as intended. The switch or the resistor assembly are the two most common problems.
on Oct 26, 2010 | Chevrolet Venture Cars & Trucks
Why does this Sharp CRT TV turn on then click off a few seconds later?
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen - Troubleshooting ... Click Here to BUY TV ...
Oct 31, 2015 | Sharp Televison & Video
1997 mazda 626 blower does not work on any speed tested motor
Yes, the hi setting should work even if the resistor is bad. Use the diagram at the link below to check the ground signals from the speed knob. With the knob on the high setting, probe the connector terminal for the wire with a white stripe. Set your meter to ohms and touch the other lead to chassis ground. There should be zero ohms. Similarly for the other speed settings, there should be one wire from the switch that is connected to ground. If not, either the ground wire to the switch is not providing ground or the switch itself is bad. http://www.bbbind.com/free_tsb.html
You can also test the resistor with your ohmmeter if you find the switch is working.
Aug 04, 2017 | Isuzu Cars & Trucks
Blower motor works resistor is not burnt and i have power just will not turn on? can i cut the ground and put a new ground in so it just runs on high?
With everything plugged in and the ignition key turned turn to run position or with the engine running ground the yellow wire at the blower resistor with a jumper wire. If the blower doesn't work ground the purple wire on the resistor. If the blower works than the resistor is bad.
If the blower works when the yellow wire is grounded turn the speed switch to lo. Pull the HVAC blower relay in the instrument panel fuse block. Two of the pins should have power and two pins should have ground. If you only have power on one pin than the switch is possible bad in the HVAC controller. If there is power on two pins and two pins are grounded try swapping the relay.
Jan 14, 2011 | 2005 Chevrolet Equinox
Ok, my blower was not working at all. It used to work on the 2 and 3 setting. I replaced the resistor nothing. Took out blower and hooked it up to 12 volts it came on. So I went and bought a new control...
the blower motor is going. It's drawing too much current and taking out the resistor pack. It has a thermal limiter that melts when the resister gets too hot. Repalce motor and resistor.
Dec 10, 2010 | Ford Focus Cars & Trucks
I would like to know how I can fix the heater in a 89 gmc k1500 with a 350 engine and no air. I tried a new heater motor and still not working. The Fuse is also good.
This is a blower motor not working tip I posted a little while back.
Nov 09, 2010 | 1989 GMC Sierra
RCA 52130 won't turn on
check for bad connections on the flyback transformer
if they are bad you will see cracks in the solder
try resistor again
Dec 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Jul 28, 2008 | 2002 Pontiac Grand Prix
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
